E21 front brake upgrades
Perfect!!!
Just the info i needed. I must say i´m impressed with the overall detail and workmanship.
If the brakes work half as good as it looks, they are awesome.
I will join you on the quest for 270 mm discs with the right offset.
1972 2002 Tii
1973 2002
1978 320/6
1985 535i
1987 M3
1986 M3
1981 Alpina B7 turbo
1992 316i
2001 530d touring
1973 2002
1978 320/6
1985 535i
1987 M3
1986 M3
1992 316i
2001 530d touring
Top work!!
Nice walk through with the photos also.
I love this car
Did you swap your whole rear end or just do the disc conversion?
Or did the US 320i come with rear disc??
My 318i still has drum in the back. I have 323i setup up front though.
Cheers
Windy
I love this car
Cheers
Windy
BMW E21 - 1982 318i
[img]http://members.optusnet.com.au/hsv912/sigjul06.jpg[/img]
Just did mine!
Girling Caliper - Left - cleaned up, right - as supplied, new old stock.
Painting WIP
Mounted - Wheels off
Mounted - Wheels on
Calipers' paintwork need to be touched up. Will do when I have time.
Rear Disc -
Rear Calipers - Wheel mounted
Painting WIP
Mounted - Wheels on
Rear Disc -
Power is nothing without control
e21 320/6 1983
Citroen ZX 1.8i SW
[img]http://e21.tricord.be/members/ichiwan2/ichiwan2.JPG[/img]
[url]http://www.frappr.com/bmwe21ownersaroundtheglobe[/url]
e21 320/6 1983
Citroen ZX 1.8i SW
270mm brake discs
the early 735i had 280mm rear discs i think you would have to have the lug holes redrilled thank you god for the bmw etk
Your brake system really looks nice. Great job. We have just purchased a 1979 e21 320i as a project car to launch our new Classic car catalog. As a final up grade I was planning on installing an m42 or m44 engine and trans. Any thought on that?jrcook320 wrote:Thanks guys. Now all I need is 270mm rotors so I can push my calipers all the way out.
Al Hafner
Al,
Hope you don't mind me interfering here. If you want to make it something special why not fit the E30 M3's S14 engine? A relatively simple swap as the S14's bottom end is based on the 320i M10. Same engine mounts!
Believe the US version delivers 185 HP, good enough. Probably not the cheapest engine to buy, but I've heard wrecked M3's go for abt $ 2-3K. That provides you with the right engine, wiring and gearbox. Depends on the damage of course but I heard a M3 with severe side damage leaving all vital parts in tact sold for 2K a while ago... something like that would be a great opportunity!
- jrcook320
Thanks Al. I'm no expert on the m42, but I've heard it said that the m42/m44 is the poor man's S14. Its a high tech motor, and you could probably rebuild one for the price of a S14 core. I personally would go with the m42 for the forged internals. The extra .1 liter displacement of the m44 isn't worth the hassle of obd2 and weaker internals. As for m42 over m20, it depends on what you end up doing to the m42. I'd like to see an e21 that is scary fast, much like your e30 RS m50. To do attain this with an m42 would require force induction. Of course, an NA stroker setup with independant throttle bodies would be awesome and would also carry over to the e30/e36 318i market, which might actually make it worth developing. Look forward to getting my classic catalog soon.al@bmp wrote:Your brake system really looks nice. Great job. We have just purchased a 1979 e21 320i as a project car to launch our new Classic car catalog. As a final up grade I was planning on installing an m42 or m44 engine and trans. Any thought on that?jrcook320 wrote:Thanks guys. Now all I need is 270mm rotors so I can push my calipers all the way out.
Al Hafner
Looking at your catalog... I just noticed you already have the multi throttle intake for the m42/m44. Now that would be cool in an e21.
Thanks for you answer, i think that you talk about the surface of the pad no? And wath about the brakin distributor? My car original was a 318i and i put them the 323i mechanical. When i put the rear disc brake i forgoten to change the braking distributor. Are de 318i and 323i BD similar? they are possible to be regulated? If the BD are not the same i will try to fit the e12 BD.
Thanks and greetings from spain.
