Clutch master cylinder question
E21meister
Post by E21meister »
The clutch master cylinder on my 323i is leaking badly, so I need to get a replacement. Does anyone know however, if you can get a refurb kit for these, or what other BMW or indeed other cars use this particular master cylinder?
Re: Clutch master cylinder question
Real OEM tells you what other models used a specific part.
Just checked and all models of e21 used the same part but it wasn't used on any other series of cars.
If you can't find a rebuild kit, buy a cheap alternative cylinder and just fit the internals.
E21meister
That's the conclusion I've come to. The other alternative is to use an E30 one and make a new pipe (the one that connects to the slave cylinder on the 'box), but that's a last resort.
Lars-Nord
Post by Lars-Nord »
W&N has a refurb kit and the cylinder. BMW has also the kit and the cylinder.
And I have the kit and the cylinder. :(
81 e21 323i polaris
mr edd
Post by mr edd »
lucas girling service kit for e21 ate clutch mastercylinder ...sp 3648..(no kit listed for fag mastercylinder) you might be able to order this by kit number at a car shop or garage ...i don't think a e21 will be listed in any current girling parts book because of the age ....edd ...p.s I can email you a scan of the full e21 page out of girling parts book if needed ( photobucket seem to lower the res on upload and the part numbers can't be seen after)
e21 316 (1981) TRE702X.
E21meister
mr edd wrote:lucas girling service kit for e21 ate clutch mastercylinder ...sp 3648..(no kit listed for fag mastercylinder) you might be able to order this by kit number at a car shop or garage ...i don't think a e21 will be listed in any current girling parts book because of the age ....edd ...p.s I can email you a scan of the full e21 page out of girling parts book if needed ( photobucket seem to lower the res on upload and the part numbers can't be seen after)
That would be great if you can, thanks.
mr edd
Post by mr edd »
e21 meister if you want a photo scan of the e21 girling brake parts page then send me a p.m with the email address you would like it sent to....edd...
E21meister
Does anyone know if the internals of an E30 clutch master cylinder are the same as an E21 equivalent? I know the inlet for the clutch fluid pipe is in a different place, but otherwise it looks the same externally.
Would the dimensions of the internal parts differ between say, a Girling or an ATE?
Reck
Post by Reck »
I bought one off RetroB which I'm sure was an E30 cyl (can you confirm if reading this?) but it works fine. :)
