Bracket for power steering on m10
raseeda green
Post by raseeda green »
Hi,
I have the 316 Classic 1.8
Is it possible to upgrade the E21 standard 316 to have power steering, I been told that the M10 engine will need a bracket/ mount inorder to hold the steering pump. If so where can I get this bracket / make one? :? If not I ll make the wife do pressups to gain extra mussle in bicieps...
Thanks.
316 auto raseeda green
323 red m52 modified
tommi_e21
Re: Bracket for power steering on m10
Post by tommi_e21 »
i say pressups!!!
m10 power steering pumps are rare :) well i cant ever seem to hear of any
Audi 50 RS
Jason_323i
Post by Jason_323i »
Buy them at the dealer
if the set came from a m20 you need the brackets at the side, the alternator brackert should swap over
http://bmwfans.info/parts/catalog/E21/S ... upport/#01
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
mr edd
Post by mr edd »
This is what a e21/m10 power steering pump and bracket looks like ..you could use a pump and bracket off a e30 m10 but you would have to change the connection on the hose from the pump to the rack..either way you will have to fit a tripple pulley to the front of you engine in place of the single pulley normally fitted ..edd..
e21 316 (1981) TRE702X.
Jazziat
Post by Jazziat »
you can also use the pump of E-28 ... i think it should fit with its original brackets ... maybe some minor modifications could help .... i have done this with my E-21 when i destroyed my power steering pump ... i got an E-28 one ;)
Its not how fast you drive .... its how you drive fast ... !!!
My current Project:
E-21 M10B20 Turbo (In Progress) ;)
raseeda green
Thanks for the advise, guys, I will do this as soon a a good sunny day allows me...
