- petroscf
Re: My 1977 316
Ok,I'll have them in mind when the time comes to replace my Michelins
/oo=00=oo\
E21 Forever
E21 Forever
- petroscf
Re: My 1977 316
Why do I hear "coughing" from the filter at cold (when temp is really low-as today : 4 degrees celsius) starts?
Here's the description:
I turn the key, and it "coughs" once or twice and does not start. Then, I turn the key again, and it starts, (no more coughing), and idles with only the normal "problems" of being cold (I have to have the choke pulled out in order to help it keep the revs up, until it gets warm)
And another issue: when I have the choke pulled out, pressing the accelerator has a somehow "empty" response, I have to close the choke in order to have normal throttle response
/oo=00=oo\
E21 Forever
E21 Forever
- petroscf
Re: My 1977 316
I am planning to remove my front fog lights, as they can't exist together with the BBS front spoiler.
So I am also going to remove the switch from the dash as it's going to be useless. I was thinking to fit a second lighter in the hole.. Not a smoker, but I believe that a second 12V plug would be more than helpful (sometimes you need to charge at the same time 2 mobile phones, or a phone and the GPS and so on.)
Can anyone tell me whether a lighter would fit there?
/oo=00=oo\
E21 Forever
E21 Forever
- petroscf
Re: My 1977 316
Pics from Sunday restauration, as promised, for whom might be interested:
/oo=00=oo\
E21 Forever
E21 Forever
- petroscf
Re: My 1977 316
Now hope to make a picture of how perfectly it is illuminating now...By night, of course!!!!
/oo=00=oo\
E21 Forever
E21 Forever
Re: My 1977 316
Is your fan missing a blade? In that case the unbalance may cause excessive wear on the water pump.
- petroscf
Re: My 1977 316
How do you make this out????
I don't know, I don't think so....(and anyway, how can I look into this??)
/oo=00=oo\
E21 Forever
E21 Forever
- petroscf
Re: My 1977 316
Oh, I see...Well, I have always remembered it this way...
Should it have one more blade there? I have to look into this...
can I easily find a new one?
/oo=00=oo\
E21 Forever
E21 Forever
Re: My 1977 316
Sometimes it's optical dilusion (or plain blindness lol) but the blades should of course be spread evenly, like in the pics below. If that's the case it may be just the picture and the fan might be ok??
- petroscf
Re: My 1977 316
No, I now also think it is like you say!!!!!!
I have to check this.
Tell me please, these pictures show, if I understand well, the upper the fan for M10, and the lower the fan for M20? So am I right to look for a fan like the one in the upper picture?
/oo=00=oo\
E21 Forever
E21 Forever
Re: My 1977 316
that's correct, even though I think I saw some 4 cil E21's with more (9) blades as well but perhaps my memory is not serving me correctly. There must be some reason why there's this sign down the driveway that's says 'home for the mentally challenged'
- petroscf
Re: My 1977 316
Thanks Jeroen!!
I will look into the matter and post the news in here...
Anyway, If I am to go for a new one, I think I should look for the M10 one...Would I have any reason to fit an M20 9-bladed fan?
If it would work better in hot Greek summer, I might consider it...However, I have already fitted a thermostat for south climates, and the temperature, even in the summer, never climbs up to more than on quarter of the scale
Might everything work better by fitting the 9blade fan?
/oo=00=oo\
E21 Forever
E21 Forever
Re: My 1977 316
Chances are quite big the lug pattern on both cogwheels or the depth is different so you can't fit the M20 version with the viscous coupling but I'm not sure, haven't done too much M10 stuff the past 20 years I'm afraid. If you never had huge temp probs why change anyway?
