front jack points repair
Vic
Post by Vic »
Hi Guys,
I wanted to know if anyone has had to have their jacking points replaced, they're the emergency ones; mines are really pushed in and need replacing. Even the one of the frame legs that runs under floor pans need some work on, are these also available separate or do they come with the new floor pans as I may replace if need be?
Appreciate any help!
Kind regards
Re: front jack points repair
Jason_323i
Post by Jason_323i »
They are not jacking points, jack the car up there and they fold in crack let in water then rust out. The where used to support on the bare shell on the factory production line.
But is you want new bits http://www.wallothnesch.com/e/body/bodye21.htm
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
