Pic needed front left on full lock
JTY
My E21(s): 1981 323i
Post by JTY »
Hi guys
Does anyone have a pic shot from a low angle that shows the left front wheel on full lock towards the right? Preferably 15" wheel...
My e21 is a bare shell at the moment and I'm making up a bracket to fit a competition towing eye. I need a good view on the clearance of the wheel to the front part of the inner wing below the bumper bracket.
Many thanks in advance.
Jeroen T.
Reck
Re: Pic needed front left on full lock
Post by Reck »
While someones there can they take a pic of where the control arm connects to the ARB (at full lock) as I'm not entirely sure my mechanic has installed properly - there's a gap between the washer and the bush which I'm sure should be tight?
mr edd
Post by mr edd »
Reck! from memory the side of the control arm that faces the rear of the car(the side with the 22mm roll bar nut ) is normally tight up to the washer and the otherside which is to the front of the car has a gap between the washer and the arm ...if you split the control arm bush while driving the washer at the front stops the arm moveing all over the place ( this happened to me on both sides at the same time and the steering felt a bit loose to say the least !) ...edd
e21 316 (1981) TRE702X.
mr edd
Post by mr edd »
murran
Post by murran »
ignoring my homemade poly bush insert....
Reck
Post by Reck »
Ahh makes sense! Cheers :)
Why'd you put a homemade bush there Murran? Just to tighten things up?
(Sorry for the hijack JTY!)
JTY
Post by JTY »
No worries for the hijack ;) Seen what I wanted to see live meanwhile :)
murran
Post by murran »
Reck wrote:Why'd you put a homemade bush there Murran? Just to tighten things up?
that was the idea, dunno whether its made any difference but i enjoyed making them. :)
