Help here .. I have a 1983 m10 e21 320i .. i have removed everything for the head gasket replacement .. have al the gaskets to replace everything i think . however there are 2 hose connections i have not found where they go..
one on the back of the head closest to the firewall.. sticking out of the head and the other seems to be a water hose coming off the back of the water punp line headed to the heater..
Any help here would be appreciated
Thank you
Head Gasket replacement
Re: Head Gasket replacement
Here are the pictures of the 2 hose locations i was talking about .. anyone out there ???
appreciate any help here..
Thank you
Thank you
Your pictures i can't see but it could be that you the hoses are for the heater of the car. The connecttions comming through the firewall.
The heater has two hose-connections. One from the head and one from the thermostathousing.
The hose from the head is the feed towards the heater. In the 320/6 and 316 of us there is a valve between which is connected with the panel inside for the temperature of the heater. There are type's of heaters that that valve is inside the car on the inner side of the firewall.
the one is actually on the block no ton the head its a small hose, the one from the back of the water pump is as well
the site wont let me post the pictures unless osmeone can tell me how
Thank you
Thank you
- DrGonzoPOW
Upload them to photobucket.com then copy and paste the IMG code/address that should be displayed below the photos in the gallery once they are uploaded. It should look like this....
[IMG]http://i343.photobucket.com/albums/o456 ... C00740.jpg
Ive deleted the last part so the photo wont display but if you just paste that code into this text box it should show your picture
Wakefield Hellfire
here are the pictures i hope ..lol
Hope you can see them and give any help on where these last two hoses go..
Thank you
Thank you
do they go to the throttle body? some throttle bodys have a coolat heat bit in them....
the small outlet closest to the front of the car runs to the underneath of the throttle body. The one closest to the firewall runs to the side of the throttle body.
