Solex 4A1 (320/6)
redline
Solex 4A1 (320/6)
Post by redline »
My 4A1 is leaking. This is kinda "normal" for this carb of a certain age. My questions are:
1 Is this due to the gasket or the carb is warped?
2 will a repair/service kit solve my problem?
Cheers
Re: Solex 4A1 (320/6)
That depends what is leaking offcourse.
A standard repairset has the gaskets of the complete carb. The bottemgasket (the thick one) is not in the set included.
redline
Post by redline »
It is leaking petrol (gas to some folks). Petrol is dripping at the bottom of the carb on the outside. Petrol is also leaking inside the throat and jets.
Reck
Post by Reck »
Get a Weber!
This means indeed that the gaskets are worn. Please make sure that you fasten the carbpart at the right torq. If you fasten them to much you disform the three main parts and you keep leaking fuel and air.
Or indeed convert to a weber.
redline
Post by redline »
i am indeed considering a weber......do you know where I can order one??? I am in Asia.
Tato
My E21(s): 1980 E21 316/1 manual
Post by Tato »
You can buy a complete kit right here.
http://www.racetep.com/weber/bmwkit.html
Kit number is K248. It replaces Solex 4a1.
It is a very good upgrade.
Not cheap.
Regards,
1980 316/1
redline
Post by redline »
on the order form the k248 is listed to fit Mercedes Benz........i supose it is the same.............. :hammer
DrGonzoPOW
Post by DrGonzoPOW »
Who's going to be the first to say.......(whisper-325)
Wakefield Hellfire
murran
Post by murran »
DrGonzoPOW wrote:Who's going to be the first to say.......(whisper-325)
lol at gonzo, i'll say it... fit injection from an e30 325i, attached to the e30 injection will be an engine....... fit that bit too. :launch
redline
Post by redline »
naughty..naugthy...........now i must sleep on it..........
