316 carb problems
quinn_656
316 carb problems
Post by quinn_656 »
Men
My uncle bought a saphire blue 316 at the weekend real good shell but with the usual e21 problems i.e. the the rotten jacking points etc but unmolested and garaged most of its later life.
first thing i want to do is to get it running and especially idling on the button. the engine starts no problem and sounds real healthy but it wont idle on its own you have to keep giving it throttle although i think it will idle on the choke when it is cold.
the carb is a peirburg
anyone able to point me in the right direction?
Willy
My build
www.quinnpiling.com
Reck
Re: 316 carb problems
Post by Reck »
You were probably expecting this but.. Just get a Weber!
quinn_656
Post by quinn_656 »
When you say just get a weber do you mean convert it to side drafts or is their a direct replacement weber for the pierburg that i can rob off something else?? i am under the impression that this is a common fault on the 316!
willy
My build
www.quinnpiling.com
Reck
Post by Reck »
Direct replacement. You'll want a Weber 32/34 DMTL (think it needs an adapter plate with it for an M10 too). Mark had one for sale not long ago.
It seems to be the universally recommended upgrade. Gets you a few more horsies, better fuel economy (if you drive 'normally' :launch ) and is generally more reliable.
You can also fit twins;
Do the air flow valve and the set thermo actuator (nr 5 and 18) click when you make contact?
quinn_656
Post by quinn_656 »
Thanks Wilmo but i think you have the wrong diagram the car is automatic and has a peirburg zenith 2b4 carb
http://bmwfans.info/parts/catalog/E21/S ... ettor_2b4/
My build
www.quinnpiling.com
Ah yes, I didn't think of the fact the 316 could have another Pierburg.
Just checking to see if you were paying attention! :wink:
quinn_656
Post by quinn_656 »
it took me a while to catch on that it was a different carb,after much confusion lol
My build
www.quinnpiling.com
