Cooling; Removing engine driven radiator fan
Aus323i
My E21(s): 1981 EU 323i Auto
Post by Aus323i »
Hey everyone,
Small problem. I've been trying to remove the engine-driven fan and have talked to people at a BM garage where they told me to use a 32mm (not sure what that is in imperial) to undo the bolt at the back of the fan. Reverse thread.
I've also seen somewhere that you are meant to undo 4 bolts on the reverse side of the fan which holds the fan mechanism together
Anyone have a solution to this? Its a bit of an amateur problem and don't 100% know how to word everything but I've got to find out somehow haha
Regards,
Max
Re: Cooling; Removing engine driven radiator fan
Yes, you need to use a 32mm spanner to undo the fan and yes it is reverse thread! But you need to block the fan, because else it will be slipping on the fanbelt. Some suppliers will provide tools to block the pully of the waterpump, but you propably can make it yourself. It can be a pain to remove when it is on there for some years :bag
If you undo the 4 pcs 10mm head bolts the fan pulley will come loose, but it won't get you anywhere as the fan isn't on the pulley. There are tools that can be fitted using two of these bolts so you can stop the water pump from moving when you try to undo the 32mm fan bolt, basically a long piece of flat metal with two holes in it that you can easily make yourself.
But most times I'm able to undo the large nut without this 'tool'.
Stand on the left hand side of the engine bay (fusebox side)
Make sure the fan belt is under enough tension
Place the 32mm spanner, best is to have it point slightly to the right (away from you)
Put on workman's gloves or whatever they're called
With your right hand, push the fan belt down go obtain extra tension (usually I use a short piece of a 2x3", that's safer)
With the extra tension on to prevent rotation, use your left hand to pull the spanner towards you in one strong pull
Especially with M20's with the 32mm nut, for me this does the job 90% of the time.
Aus323i
Post by Aus323i »
Thanks, for the quick reply both of you. I'll go down and give that a try right now.
I'll be back with the results soon
Cheers,
Max
I Always smack the nut with a chisel so it is going clock wise. A couple of swift taps always gets it off with minimum fuss.
Never tried that one, but in some cases I just hit the spanner with a hammer, especially if there's no room for other solutions like with the later 6 cil engines M52-M52 etc. Since you don't hit the water pump on the head but in its normal direction I think you're less likely to do any damage to the water pump.
Just be careful not to hit anything else... I just broke the fan shroud on my girlfriends car. Only hit the shroud slightly but in the cold that's enough to break it :roll:
Aus323i
Post by Aus323i »
Thanks Jeroen for the help,
I have been very unsuccessful though.
I cannot seem to put enough pressure on the fan belt to stop the water pump from moving. Yet, the band
So I do think that some fabrication is in need to create myself this tool..
It just cant seem go the easy way haha
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
Post by cobbler2u »
Id go with what nas said. Give it a few wacks its the easiest way
Try and borrow an impact gun.
Aus323i
Post by Aus323i »
I'll go give that a try before making this tool then,
The previous owner had a go at making this tool and I have his attempt but the holes he drilled to hold the two bolts in are no where near big enough
Right, time to go give it a smack. I'll be back with how I went soon haha
There are two approaches for this tool, one is to remove two bolts and put them back in with the tool fitted, this is the safe way. There are also tools that just go over the heads of the bolts but in that way it is easy to damage the heads and the tool can come off easily as well, too.
You just need a long-ish cold chisel and a hammer. Remember its reverse thread. Bang the edge of the nut clockwise and it'll just free itself.
pampa
My E21(s): 1982 E21 323i 5spd .1967 Triumph TR4a
Post by pampa »
I got mine off with a length of flat steel with hole drilled in end corner,bolted to one of the small pully bolts then give 32mm spanner a big whack with a hammer(make that a lot of whacks) and it finally came loose.
trash-berd
My E21(s): '82 320i US Manual 1.8L
Facebook page: https://www.facebook.com/eli.tripi.5
Post by trash-berd »
What if said bolt doesn't seem to exist?
Aus323i
Post by Aus323i »
I can't help you there, sorry.
But for those that do have a nut
http://www.ebay.com.au/itm/BMW-32mm-Fan ... 9b9&_uhb=1
There is a tool specifically designed for it. I wasn't able to fabricate one and I just needed to get it off.
Great quality and good shipping time
Max
