Seals - leaks - solutions
arshad76
Re: Seals - leaks - solutions
Post by arshad76 »
drjim wrote:Yep, smaller bore pvc tube slid in with a coating of glue that lubed then sealed when it set. I think I pulled the hose right through the hole at the bottom rather than letting it drain into the sills.
Long time ago that I did that job for you Arshad!
Yep, NHS forceps make fine e21 sunroof hose pulling apparatus too as I recall!
UK Moderator
drjim
Post by drjim »
My big long forceps have vanished - very upset.
1982 Saphirblau Baur 325i
Cars all gone!
Eddie.
My E21(s): [O==[][]==O]
Post by Eddie. »
I need to do this sort of thing too, draining into the sill is madness!
