bmw 316 tuning info
harleytrike
bmw 316 tuning info
Post by harleytrike »
i might be getting a bmw e21 316 and im planning on tuning the engine so im looking for information on the best route to do this as i dont really want to do an engine transplant
croma_man
My E21(s): '83 EU 327i
Re: bmw 316 tuning info
Post by croma_man »
turbocharged M10B16 or M10B20 tuning with either ITB's and standalone ecu or twin webers.
petroscf
My E21(s): '77 EU 316 manual
Post by petroscf »
croma_man wrote:turbocharged M10B16 or M10B20 tuning with either ITB's and standalone ecu or twin webers.
Well, is an M10B16 strong enough to get turbocharged? Wouldn't it need a head replacement?
/oo=00=oo\
E21 Forever
You could import the kit from America, where turbo'd e21 are more common?
Jim managed to get 170 brake from his m10 but it cost a few quid. Cheapest route is bigger valves, flowed head & fast road cam and either a set of 40's or once you get pissed off with fuel stops, a single weber. About 140 brake should be easily achievable.
petroscf
Post by petroscf »
e21-Mark wrote:You could import the kit from America, where turbo'd e21 are more common?
140 from 1.6?
/oo=00=oo\
E21 Forever
Enjoy.
A 2002ti made 120bhp from the factory, so no reason why an e21 1.8 can't make decent power. Just depends how much you want to spend getting it? Having the head flowed, bigger valves and a high lift cam isn't cheap. You' might also be wanting standalone ignition and mapping, so there's another £1k there. Bottom line is you'll still need to pull the engine apart to modify it, or bolt on forced induction. I guess that's what makes engine swaps an attractive option, but I know Matt said it's not a route he wants to take.
petroscf
Post by petroscf »
Oh, yes, I 'd forgotten that
/oo=00=oo\
E21 Forever
drjim
Post by drjim »
My engine was a 2L, fully stripped balanced rebuilt with overbore high comp pistons. Adaptor plate for s14 ITB setup, DTA ECU, crank trigger, coilpacks. Cat cams camshaft (lowish spec not as big as I'd like but it was what I had) and lightened flywheel. Probably does hit 170bhp on a good day, but I spent 2k on machining/building and ECU. Plus 200 quid for the engine in the first place, 600 for the pistons, 150 for the cam, plus all the other bits.
Why? I had a crazy dream to race in the CNC heads series at Oulton park, and using the original type of engine put me in class E, I could ask for race number 21 and therein lies the madness.
Do an engine swap mate, or accept what you have. Minute you start looking at cams or better carbs or EFI you are spending as much as doing a swap. I know I'd do a swap given my time again.
1982 Saphirblau Baur 325i
Cars all gone!
