Mark's 316 M52/2.8 + Cat cams & Jenvey ITB's
- e21-Mark
Re: Mark's M52/2.8 + nitrous
Wurth underbody protection.
- e21-Mark
No, it dries but has a rubberised texture I believe. Obviously prep is everything.
The stuff from Wurth and 3M is great, and can be resprayed as well if you like.
So if you touched it you wont get horrible tar like crap over your hands?
I hate that sticky underseal stuff that never dries... Makes working on cars a right chore..
- e21-Mark
No, that's just cheap underseal and not the same stuff at all.nas80 wrote:So if you touched it you wont get horrible tar like crap over your hands?
Have had to bite the bullet and buy new Gaz coilovers for the front, as the old ones had corroded so badly internally.
Dang thats bad news eh. They couldnt replace the damper inside?
- e21-Mark
No, Gaz said it was too far gone unfortunately. It's a shame though, because they'd originally been made by Tansautosport and were based on the Grp5 leg type with removable upside down Bilstein insert. It turns out the rears are Escort RS Cosworth competition units, which explains why they're such heavy duty I guess? I've kept all the springs for the track car though, as they're ex county race car.
I guess there's plenty to do while waiting for Gaz but I was looking forward to finally seeing my car back on its wheels again.
pandemonium001
- My E21(s): E12 535i T (ish)
Thats handy to know the escort ones are roughly the right length. What top mounts where fitted? any pics?
- e21-Mark
- Jason_323i
They do fit but you have to redrill the top mounts that was how they where made, I bought all the TAS e21 stock when they went bust including the coil over strut tubes. They are not group 5 based they are an escort rally copy which run inverted bilstens. Good tech in the day as the larger diameter tube was stonger but new gaz is better ans the strut body is larger diameter.
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
- e21-Mark
Ah right, there we go then. I guess it's been a few years and the info wasn't quite as fresh as it could have been. At least we were able to salvage the bits needed to have Gaz make the replacements.
- e21-Mark
