Wilwood 4 pot fitting - walkthrough
Re: Wilwood 4 pot fitting - walkthrough
I'll be removing my wilwood powerlite's at the weekend so can look at the brackets and measurements. They will also be for sale.
Ben
Ben
harleytrike
what calipers you putting on instead of the wilwoods
Wilwood Superlite on 296mm discs.
Ben
Ben
harleytrike
sounds silly but whats the difference and is the rest of your brake setup standard e21? could do with a brake upgrade myself in my m52 powered e21
I'll be taking some piccies of old and new over the weekend. But basically I've gone for the same piston size and disc width as the powerlite setup but the pads are 50% bigger than the powerlite's.
Currently my brake system is all std apart from braided lines front powerlite calipers and pad materials. Will be going 296mm discs up front with the larger Superlite calipers. I am also going to fit E30 rear calipers to enable a better selection of pads for the rear.
Front:
std E21 pad surface area = 3348 mm2
Wilwood powerlite pad surface area = 3136 mm2
Wilwood Superlite pad surface area = 4728 mm2
Rear:
std E21 pad surface area = 1653 mm2
std E30 pad surface area = 2002 mm2
Ben
Front:
Rear:
Ben
harleytrike
what discs will you be using
Same calipers as me but with slightly larger 300mm floating disks and with minilites on the rear, again 300mm.Duracel79 wrote:Wilwood Superlite on 296mm discs.
Ben
- TopCat
- My E21(s): 1980 Alpina B6 2.8
- Facebook page: https://www.facebook.com/timothy.c.boles
dear Duracell
Do the powerlites bolt right up to standard discs BAC?
If so I should have had them off you rather than the Volvo jobs I have bought?
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
Topcat
With the correct bracket, Yes they will fit to std ø255mm 323i discs:TopCat wrote:dear Duracell
I still need to measure the bracket and draw it up for you guys.
I'll try and get some measurements before they a picked up.
Ben
That would be great.
I still do not have brakes on my car (
Could you also measure the brackets needed for the Superlite upgrade?
and the calipers/disks id's?
Why didn't you go to e34 302mm disks? their hats do fit us quite well I thought..
- croma_man
- My E21(s): '83 EU 327i
does anybody have any discounts or know where to buy a wilwood set (calipers, discs, pads, lines) ?
Calipers and pads came from Rally Design and they offer decent prices. For pads I'm personally not that happy with the Wilwood ones, threw them in the bin and fitted Ferodo DS2500 P/N FRP3108. Lines are custom, the usual hydraulics specialists like Pirtek should be able to do that for you.
More useful info here for example http://www.bmwe21.net/forum/viewtopic.php?f=3&t=16261
What's missing then is the brackets, still chasing a manufacturer for those, hope to meet him again -after ages- next week...
- croma_man
thanks for the link(s), enough info to sort a set out for my friend who wants to have good brakes.
- petroscf
Can you please give an order link?Jeroen wrote:I wasn't to pleased with Wilwood's fast road pads, but nowadays you can get Ferodo DS2500 for the Powerlite 120-8729 4 piston unit and they are pretty good for both road and the occasional trackday. I used them myself for a few track laps and on 2 trips to the Alps already. Ferodo model FRP3108.
I can't seem to find these easily in Greece!
Or else, any alternatives?
/oo=00=oo\
E21 Forever
E21 Forever
Any Ferodo dealer I guess. And our sponsors Hardeman as well probably!
