Speedometer correction factors
Muke
Post by Muke »
3771489 wrote:
Btw 0,854 is from 520/4 or 520A/4 :roll:
You are right.
Life without K-Jetronic... There is no life, without K-Jetronic
1800TI -64 Polaris-metallic
320i -77 Verona
323i -78 Golf
323i -78 Sierrabeige
ALPINA B6-2,8 -82
M3 Sport Evolution -90
superj
Post by superj »
ok, this came out of a 4 cylinder american 320i with auto tranny.
no number on the face
sticker on the back
came out of the white one
[img]http://i25.photobucket.com/albums/c80/busemans/cristinaavatar.jpg[/img]
this could be great tattoo
HaroldShand
Speedo correction factor
Post by HaroldShand »
Hope you don't mind me replying to this old post, but as you appear to be the resident expert on these matters...
I have 2 problems with my speedo:
Chronic: speedo wavers from rest up to speed then settles.
Acute: the mileometer and trip meter stopped turning today.
My mechanic has advised replacing the speedo as he is unable to fix the gears and a friend told me that replacing the cable would stop the juddering needle problem.
Going with this advice to replace both, I just want to make sure I get the right parts !
I have a 1982 UK 323i automatic. I have standard 5.5x13 wheels shod with 205/60 R13 86H tyres all round. Taking into account the non-standard tyres, is there a more appropriate speedo to get than the one I currently have ? ( W = 1.220 EG )
Kind regards, H
Arnold D
Post by Arnold D »
Mine is a 323i, build 3/1981. Has a 5 speed sport and limited slip diff.
W 0,762
According to my GPS, 1 KM off.
Tyres 195-55-15
Mine is a 323i with an Eco-fivespeed gearbox and a standard 3.45 diff
W = 0762
According to the tomtom it is right-on. The original tyresetting so 185/70 13.
Arnold D
Post by Arnold D »
My Alpina B6-2.8 built 10-1980.
Sticker on the back says W762. Limited slip diff.
mcjjordan
My E21(s): Uk 1980 316 m52
Re: Speedometer correction factors
Post by mcjjordan »
1.393
1980 316 4 speed uk mph
it screams on motorway!!! really too high revving
Fits the list posted previously I guess:
1,465 0-120 315,316,318,318A 4,10 or 4,11
1,393 0-120 320(A)/4,316(A)1.8,318i(A),320(A)1.8i 3,91
1,300 0-140 320i(2.0iA(US)),320(A)/6 3,64
1,220 0-140 323i 3,45
1,360 0-140 320i(1.8i)US 3,91
1,266 0-140 320iA(1.8i(US)) 3,64
mcjjordan
Post by mcjjordan »
mcjjordan wrote:1.393
70mph its revving at 4000rpm!
mcjjordan
Post by mcjjordan »
found a lovely calculator for working out variants
http://johnmaherracing.com/calculators/ ... alculator/
mcjjordan
Post by mcjjordan »
So i have 2 speedos
1393 & 1300
So what diff ratios are these for?
See page 2
petroscf
My E21(s): '77 EU 316 manual
Post by petroscf »
My car original speedo is the one without anything written on it. (Pre facelift 316 1.6 with 4 speed manual and 4.10 open diff)
With the engine (and diff and gearbox) swap the new set up is: W=0762eg speedo, with 3.64 diff and sport 5 speed gearbox (5th gear is 1:1)
So I guess that my current speedo is probably from a 323i, thus, made ideally to match a 3.45 diff?
How should these correction factors be interpreted exactly? I haven't understood
/oo=00=oo\
E21 Forever
Indy555
Post by Indy555 »
Simple example: You have a speedo with w=0762, this means on 1000m Your diff turns 762 times (if it's the right 3.45). That's what Your speedo expects.
If You have a 762 speedo and a 3.64 diff, Your Diff turns faster, than the speedo expects, so Your speed is shown up higher, than is is.
0808 to 762 in this case..means 5.7% faster than real speed.
petroscf
Post by petroscf »
Indeed!!
And based on a couple of comparisons I've done with gps, it seems you're right!
However, isn't all this also depending on wheels diameter?
/oo=00=oo\
E21 Forever
