bmw m52 engine conversion
jimbob
Re: bmw m52 engine conversion
Post by jimbob »
your cars looking realy good. i like it without the tints
E36 328i Daily driver
E36 328i Touring
+1!
harleytrike
Post by harleytrike »
Test pic of the blacked out look what do you guys think black or chrome
Chrome
Black
Please stick to the chrome
problemchild75
Post by problemchild75 »
Chrome for me
problemchild75
If you get a local wrapping firm to do it it will be cheap and you can reverse it as and when you like though
Miles better without the tints.
jimbob
Post by jimbob »
keep the chrome it realy sets your car off nicely
E36 328i Touring
harleytrike
Well ive decided to give the blacked out look a go if it doesn't grow on me ill go back to the chrome
harleytrike
Well made a start fitting the poly bush kit front arb bushes & control arms bushes fitted just the rear bushes to do now
harleytrike
My new front gaz shocks came today cant wait to get these fitted at the weekend
nice one!
problemchild75
They look a nicer Finnish to mine :smoke
harleytrike
Loads of work to do tomoz on my car fit new struts fit the rpm top mounts and the rest of the polyurethane kit then hours of getting it all set up.The joys of owning an e21
Take the rear arms off. Set the bushes on fire. Then hit with a hammer and chisel to pop em out. Then get some threaded bar and repair washers so you can pull the new poly bush through on the rear arms.
Once you done all the bushes.
Front
1 degree negative with 0 toe. 7 degrees negative caster.
Rear
1 degree negative toe
2 degrees negative camber.
Although you wont have much choice of you don't have the rear adjustable plates.
Nas
