Eddie.
Posts: 479 Joined: Mon Oct 29, 2012 11:31 am
My E21(s): [O==[][]==O]
Post
by Eddie. » Mon Mar 17, 2014 2:36 pm
I've now got the M20 in.
I'm after some help with the wiring as it really is my downfall, I'm useless at it!
Anyway, does anyone have a guide as to what needs doing? Or better still is there anyone local to Manchester who would be willing to lend me a hand one evening/weekend?
Thanks in advance
brennon
Posts: 104 Joined: Mon Oct 14, 2013 12:06 am
Post
by brennon » Mon Mar 17, 2014 10:16 pm
Which m20 have you got?
Duracel79
Posts: 817 Joined: Thu May 29, 2008 6:54 pm
Post
by Duracel79 » Mon Mar 17, 2014 10:30 pm
Eddie.
Post
by Eddie. » Tue Mar 18, 2014 12:35 am
M20B25 from a PFL E30 is the engine.
drjim
Posts: 1096 Joined: Fri Nov 03, 2006 11:32 pm
Post
by drjim » Tue Mar 18, 2014 12:24 pm
Murrans thread is the key ingredient here. That's how I did mine (with on site spannering help from Murran!). Are you wiring the c101 socket to the car or just the engine loom to the e21 fusebox via the e21 plug?
I am obviously local and have a working M20 motronic swapped car you can look at (on SORN in my Dads garage at the mo though). I am however always busy and am working this weekend.
Read Murran's thread, check the bits in my Baur rebuildathon thread and PM/call me when you get stuck.
Jim
1982 Saphirblau Baur 325i
Cars all gone!
Duracel79
Post
by Duracel79 » Tue Mar 18, 2014 4:26 pm
I also found this useful for checking the ECU and wiring after the install:
http://www.rtsauto.com/ecu-pinout-and-e ... tests-e30/
This is quite useful as well:
Don't forget the E30 engine loom needs power and earth.
Power would normally come from the starter motor terminal. Which is fed from the battery.
Ben
Duracel79 on Wed Aug 20, 2014 10:54 pm, edited 1 time in total.
Eddie.
Post
by Eddie. » Tue Mar 18, 2014 11:56 pm
Jim, I was planning to wire the loom to the E21 fuse box plug.
I'll have a look through the threads and try to put together something that will get me going. I can already see the help thread being written!
drjim
Post
by drjim » Wed Mar 19, 2014 10:18 pm
My Baur will be getting taxed on 1st April so can drive round to yours after that.
The wiring bit is actually pretty easy, just the stuff like the various plugs that can be swapped and sensors that can play up that cause issues.
Cars all gone!
Eddie.
Post
by Eddie. » Wed Mar 19, 2014 11:38 pm
That would be massively helpful, thanks Jim.
I'm going to make a start on it this weekend hopefully, so fingers crossed it'll go okay.
Duracel79
Post
by Duracel79 » Sun May 04, 2014 10:14 am
Duracel79 wrote: I also found this useful for checking the ECU and wiring after the install:
Ben
Eddie
Try the link I posted above. Full wiring checks for Motronic 1.3
Ben
Duracel79 on Wed Aug 20, 2014 10:41 pm, edited 1 time in total.
drjim
Post
by drjim » Sun May 04, 2014 10:32 pm
Need to know what ECU and loom you have, what year car is it from? What's the ECU I gave you, could be ECU and loom are incompatible...
Cars all gone!
Eddie.
Post
by Eddie. » Mon May 05, 2014 10:17 am
I've no idea what year the loom is from, I asked the breaker for a loom from a Motronic 1.3 car.
ECU is has the code ending 380.
mr edd
Posts: 253 Joined: Thu May 31, 2007 12:32 am
Post
by mr edd » Mon May 05, 2014 2:00 pm
325i/is/iX
E30
M20/B25 (170hp)
87-91
0 261 200 380
Bosch Motronic M1.3
e21 316 (1981) TRE702X.
drjim
Post
by drjim » Mon May 05, 2014 4:58 pm
Sorry I won't be around to help, been busy with Family stuff and am setting off for Cadwell park now. Don't have a gap in my schedule this week either.
In terms of fixing it quick, JAmie knows an auto sparky, or there's the garage in Sale Moor that should be able to suss it.
Speak soon
Jim
Cars all gone!
Posts: 2975 Joined: Sun Jun 14, 2009 12:12 am
Post
by nas80 » Mon May 05, 2014 4:58 pm
I had a phone call off him. He's got it going now.
