Wiper Arm - losing connection
davidvincent
My E21(s): 1982 320/6 Lapis Blau
Post by davidvincent »
320/6 M20 1982
Hi again everyone
My driver side wiper arm seems to be coming disconnected somehow at the base where it joins the plastic bracket/mounting... it actually managed to throw the arm off the screen at one point, now the motor runs but the arm barely moves at all. Motors seem fine, though.
I can't easily see how the arm is meant to engage, there's a central column which it is attached to but the motor just makes that column spin inside the arm itself - odd.
Just wondered if anyone has come across this and knows of a fix? To save me buying a replacement.
Thanks in advance.
Dave
David
"Everything in moderation, including moderation"
Re: Wiper Arm - losing connection
If my old one is still at Pristine you can have it for free, as I run a single wiper.
davidvincent
Hi Mark
Thanks for that, very kind :)
So in your opinion it'll definitely need replacing then? It just seems to be slack/loose on the bracket, I can spin it a full revolution without any force at all.
Is Pristine in Milton Keynes?
Thanks again
David
I'm not sure? Can you upload a short video?
Pristine are in Essex, but am heading over there later in the week, so can take a look?
davidvincent
Hi Mark, I'll have another look tonight and will try and sort a video too - many thanks.
David
polov8
Post by polov8 »
Sounds like the nut on the arm was loose, it's allowed the teeth on the spindle to spin inside the arm and chew it up so it won't now tighten up. In which case the arm is buggered.
Andy
davidvincent
Hi again - here's a short clip showing the fault:
Andy, I think you might be right there!
David
Yup, sadly looks like it!
davidvincent
I should have put more effort in before starting this thread.....
So it's now fixed, I flipped open the plastic cover at the base and there's a 13mm nut which just needed tightening up, problem solved!
Thanks for the help/offers/advice all the same :)
David
:hammer
:lol:
