Don't over-worry the issue, just fit 'em & drive the car.
Suspension question B4 VS B6
- AndyBaur
- My E21(s): 1983 320/6 Baur 5-speed (now gone)
Re: Suspension question B4 VS B6
I have the Spax kit. Drives well & looks good - not too high, not too low.
AndyS
E21noob
- My E21(s): SOLD
I almost popped on the spax, but as it is not tuv certified it's likely I wouldn't get through it's mot over here.
I went for sport springs from H&R that lower about 35mm, and got the bilstein sport dampers from walloth:
http://www.wallothnesch.com/stossdaempf ... 06-12.html
That will get you a nice and balanced setup. Just make sure to have enough pre-tension on the spring or the lower spring plate (height adjustable) will start rattling so don't put it too low.
E21noob
- My E21(s): SOLD
OK, thanks - will it keep in mind. I assume it will become apparent once I get things dismantled.
