Radiator cap PSI tolerance?
- JTY
- My E21(s): 1981 323i
What is the standard spec PSI tolerance for the 323i radiator cap? Having trouble looking it up. Nothing seems marked on the cap itself neither.
Say you wanted to upgrade to a Stant Racing cap (http://www.demon-tweeks.co.uk/motorspor ... er-release), what tolerance would be appropriate?
Many thanks
Jeroen T.
Many thanks
Jeroen T.
Re: Radiator cap PSI tolerance?
1 bar afaik, but why would you want to increase pressure? Keep in mind that might break other parts. I remember issues with E30 rad caps opening too late ruining heater matrixes and heater valves.
- JTY
1 bar equals abt 14.5 psi. Thanks, Jeroen. Need a new cap and just looking into the options.
Ah ok, thought you were looking into increasing pressure. Yup I think abt 15 psi is also a common value you find on the net. And they do fail on a regular basis indeed, either opening too soon or too late!
- TopCat
- My E21(s): 1980 Alpina B6 2.8
- Facebook page: https://www.facebook.com/timothy.c.boles
I like these Stant jobs very much and have them on most cars fm 22lbs on racecar
I think we run an 18lber on Herman- so far no probs
I will check if needed tonight?
Regards
Topcat
Isle of Man Inverness
1980 BMW E21 Alpina B6 2.8
1991 BMW E30 Hartge H26
Topcat
- JTY
A check always welcome and useful information, Topcat! Thx.
- TopCat
yes it is an 18-22lb Stant
Photo to follow
However please note that Herman has a Big block M30 Alpina engine with the standard 323I Radiator (with elec fan) as well as new hoses everywhere.
Herman is a genuine B6 28
Photo to follow
Regards
Topcat
Topcat
- TopCat
Regards
Topcat
Topcat
