Uwbuurman: 1986 e30 325iA cabrio
Re: Uwbuurman: 1986 e30 325iA cabrio
February 29th, 2012. Today I changed the distributionbelt, waterpump and other parts. The house of the thermostat has a little pipe on the lower side that was all corroded, and of course it broke. My spare B25, I have sitting in my garage had the same house, but also the same problem, and it also broke. Stupid fabrication.
Took of the rad, lots of workingspace!
Stupid thermostat house...
The doctor is watching
Old D belt and V belts
Waterpump of
Old and new
Now I need a new thermostat house, to change the oil, new filter in the gearbox, and fit that with new ATF, fix the brakes, replacet he fuellines, clean te interior and put it back together, put the front together, placet he new frontscreen and than for the MOT.
Smartie
My E21(s): 320/6 '78 rip
323i '78 wip
Post by Smartie »
Koos, are you refreshing old journals or something wrong with the date stamp?
Going strong!
Martin, just getting my e30 topic on the international part of the forum up to date. For my recent wprls, see this topic in the off topic section in the Dutch part. I hop to have this up to date next week.
Nice progress all over Koos!
Tnx, J!
Goed bezig Koos, fijne vakantiebesteding :-)
Thnx Walter!
On march the 5th, 2012 i had the carpet cleaned with an extractor. That vacuums i tand flushes soapwater. After that it’s dried. But before all that, the dirt has to come loose, so we used a compressor, 8 bar. We repeated this 3(!) times.
The extractor
What once was clean water…
The carpet after the treatment
And no wit has to dry.
I also cleaned the oilcollector from the gearbox. Flushed it and replaced the filter.
Underneath the gearbox, the square piece is the filter.
And I took apart the brakes.
The brake lines needed to be replaced. The old ones where heavely corroded.
Old line came apart on removal.
Producing the new copper lines.
Two new fuellines and one new brakeline!
The seals on the rear sidewindows are gone aswell. So i bought two new ones.
But no winner yet. Another piece that will be replaced…
Finished the brakelines, al the way to the ABS unit.
