I have had the car off for repairs on the gearbox. They replaced a number of gaskets and seals. That stopped the leaking, the box is now nice a2nd dry, but I still have the problem that the car goes into neutral when driving at higher speeds. But, now beiing end of May 2012, I used the car fors ome small trips around town and I like it. the car grows on me, and more important, convidence too. What I clearly feel is that the undercarriage is not so fresh anymore. Steering is a little vague, it tends to roll a lot in the corners. Nothing big, just 25 year old and used.
Did some more work on the car. My right doorpanel didn’t fit right. So i took it off. Behind it, there was no damplayer. But what I saw more didn’t make me very happy.
I suppose that there was a problem with the electric window in the past. They just cut out the middle section of the door
. Who does such a thing! In a few years I will put in a new door.
I also cleaned my interiorparts, with the plastic cleaner from Colourlock. Fe-no-me-nal!
before:
After:
On the Sharknosemeeting 2012 i bought a Hirschmann electrical antenna, just €55,--. On removal of the old antenna I found out that the old manual antenna is not even propperly connected, just some wires taped together. I was lucky to find the electrical wires in place, in the past there was an electrical antennat hat was removed when it broke down. So installation was very quick!
