Temperature gauge
yatisr
Temperature gauge
Post by yatisr »
I suspect that the temperature gauge on my 323I is over-reading. However, before I change it I want to make sure. Does anyone know what the actual temperatures are at each mark of the temperature gauge? Thanks in advance and season's greetings to all.
Yatis
Re: Temperature gauge
See the FAQ section on temp problems, usually the temp sender near the thermostat is the cause, the gauge itself usually is fine
yatisr
Post by yatisr »
Thanks Jeroen. I have read the useful information in the FAQ Section, as per your advice. By temperature sender, I assume that you mean the Remote Thermometer Sending Unit 62 11 0 788 115.
Yatis
That is correct, I'll add the part no to the FAQ as well
E21-driver
My E21(s): BMW E21 315
Post by E21-driver »
Please check also the ground connections of the engine and the engine harness and the generator. The ground connection of the engine harness is somewhere under the manifold. Maybe they have to be cleaned. They also can cause funny movements in the instruments. Check also the cable of the sensor, it may get slightly broken over the years.
M.
1982 315 reseda
