oil cooler or not? (m30B35)
Yoozt
My E21(s): Non E21: E28 525E, E12 535i
Re: oil cooler or not? (m30B35)
Post by Yoozt »
Thanks, the radiator comes from the car itself. It was a 528 in good condition, so the radiator should be fine. Off course I will check it first and flush it.
Of course there is no connector to the old one, does the B35 need this connector? (there's one on the aluminum version)
Jeroen wrote:It is always hard to compare used and new radiators, sometimes old ones are damaged, clogged up internally and with a bit of luck someone has applied a few layers of spray paint to make it look better. Then it's no miracle a new one performs better, but in basis the old type should be just fine, even on a B35. If it's a used example I'd flush it clean though.
Old ones vs new, well in both cases they should suffice as well, especially in our moderate climate and for road use. If the original solution doesn't work there's always a workaround but my approach would be to look for the cause.
Ik think Jeroen is right.
I think(not sure) the 528 radiator is a little thinner than the facelift 528i-M535i version.
If you still would like to convert here are some examples:
http://www.firstfives.org/faq/radiator_ ... pgrade.htm
Or much more about e12:
http://www.firstfives.org/faq.html
I don't know were the connector was connected to. Do you?
Here a pic how the oilcooler is originaly mounted on my M535i:
Yoozt
Post by Yoozt »
thanks for this! to be sure, we're going to use the aluminium one of the E34. I think the plug is for the temp switch for the electric fan.
Yoozt wrote:thanks for this! to be sure, we're going to use the aluminium one of the E34. I think the plug is for the temp switch for the electric fan.
If you have a visco you don't need this one.
I've got this one on my e21 and e12:
http://www.ebay.de/itm/121592115846?_tr ... EBIDX%3AIT
Works fine.
Yoozt
Post by Yoozt »
Yes, we have a new visco fan so we will use that one.
pandemonium001
My E21(s): E12 535i T (ish)
Post by pandemonium001 »
Be careful when swapping filter housings and engines, there are differences between the oil passage on the early and late m30 blocks. i cant remember which way round, but one configuration will require a bung in the block, otherwise all oil pressure will escape and zero oil to the engine.
see here
The big center round supply hole requires the bung in the block. I think.
Yoozt
Post by Yoozt »
pandemonium001 wrote:Be careful when swapping filter housings and engines, there are differences between the oil passage on the early and late m30 blocks. i cant remember which way round, but one configuration will require a bung in the block, otherwise all oil pressure will escape and zero oil to the engine.
see here
hmmm. interesting.. I didn't have a second look at the gasket....I changed the oil filter housing from cooled to not cooled and I put in a new gasket, but I don't know which one it was...to be sure I want to take it off again and buy a new one.
Which one of the 3 do I need?
pandemonium001
This thread explains better:
http://www.mye28.com/viewtopic.php?t=125891
Yoozt
Post by Yoozt »
thanks guys! I didn't know that. I took of the oil filter housing and found out that there is no plug (of course)
So I'm going to put a plug in there, not the original BMW 11 12 7 539 543 part, because they want €14,45 for one plug and i need to buy 10...
is the gasket we used (see picture) okay? (i think its gasket nr 3 on illustration) there is another gasket (12) that will probably fit better I think, but maybe the one we have now is good enough..
photo gasket:
ill:
In a few weeks, i get a breaker 635csi.
These cars do have an oilcooler.
If youre interested, you can contact me.
pandemonium001
http://www.bimmerforums.com/forum/showt ... 7d0a85f8b1
see the above thread.
Is your filter the open faced downward facing one?
if so use gasket no2, or just trim the middle bit off yours, Incase it brakes free when not clamped down and blocks the oil system as well as installing your bung.
Otherwise it should be fine.
The e34 filter housing has a self drain hole when removing the upward facing filter cap. This allows the canister to drain to the block on filter changes through the threaded hole, but stays full the rest of the time.
see my thread page 10, same gasket as you, e34m5 filter housing, no bung for draining during filter change. E34 1989 3.5 block
Yoozt
Post by Yoozt »
pandemonium001 wrote:http://www.bimmerforums.com/forum/showt ... 7d0a85f8b1
thanks for this. I'm not completely sure: We have a B35 engine with the upward facing b35 housing. We want to re-use this housing (so no down facing B34) can we install it without the plug in? so as it is now?
we use the upward facing housing without the oil cooler.
