Bilstein shocks
- petroscf
Re: Bilstein shocks
So good B8s are available again!
(I am pretty sure that, at least in Greece, they were officialy NLA -for E21- some years ago, I am glad to see them again in the catalogues-now I know what my next suspension will be.)
/oo=00=oo\
E21 Forever
E21 Forever
- Heinrich
- My E21(s): '81 323i TC-1 Baur 5-speed
Re: Bilstein shocks
Thanks a lot!
So what would you choose for Eibach springs (30-35 mm) - B6 or B8?
- petroscf
Re: Bilstein shocks
Aren't B6s produced for normal height?
So, fitting with lower springs would mean that they are "obliged" to work at lower than normal conditions
So I guess I would go for the ("sprint") B8 type
/oo=00=oo\
E21 Forever
E21 Forever
Re: Bilstein shocks
Standard or slightly lowered, up to 40mm is no issue at all imo
- Heinrich
Re: Bilstein shocks
Which one is fitted on your car Jeroen?Jeroen wrote:Standard or slightly lowered, up to 40mm is no issue at all imo
Re: Bilstein shocks
B6 all round. Even though it is said that the B8 has the same character, they felt more harsh when I had the chance to test them side by side. I don't want harsh on my cars so both the E21 and the E30 are equipped with B6, and on the Baur that sometimes even feels harsh. But that might also have to do with the stiffer front springs that were originally designated for the Alpina B6's heavier engine. On the E30 they are absolutely perfect but that remains a personal taste thing and also depends on the rest of the suspension setup.
- Heinrich
Re: Bilstein shocks
Thanks sir. Will go for the B6 then, as I prefer a confortable ride
- petroscf
Re: Bilstein shocks
Didn't Alpina offer a suspension kit, back in the days, for 323i instead of factory standard suspension?
I think it was with B8's and Eibachs(which lightly lower the car, not too much) or am I wrong?
/oo=00=oo\
E21 Forever
E21 Forever
- petroscf
Re: Bilstein shocks
To be more precise, and iirc, kit also included 15" alloys, 6" wide front and 7" wide rearpetroscf wrote:Didn't Alpina offer a suspension kit, back in the days, for 323i instead of factory standard suspension?
/oo=00=oo\
E21 Forever
E21 Forever
Re: Bilstein shocks
Do something out of the ordinary and try the Alpina pages on bmwe21.net
- petroscf
Re: Bilstein shocks
Jeroen wrote:Do something out of the ordinary and try the Alpina pages on bmwe21.net
OK, will do
/oo=00=oo\
E21 Forever
E21 Forever
- so.net@sfr.fr
- Newbee
- My E21(s): 9/81 323i manual schwarz
Re: Bilstein shocks
That's my advice too. I've had B8, but they are very hard. Now, with the B6, the car has the good compromise without hurting the body.Jeroen wrote:B6 all round. Even though it is said that the B8 has the same character, they felt more harsh when I had the chance to test them side by side. I don't want harsh on my cars so both the E21 and the E30 are equipped with B6, and on the Baur that sometimes even feels harsh. But that might also have to do with the stiffer front springs that were originally designated for the Alpina B6's heavier engine. On the E30 they are absolutely perfect but that remains a personal taste thing and also depends on the rest of the suspension setup.
Moutinho
- My E21(s): ´79 Euro 320/6 5speed Manual
Re: Bilstein shocks
is there any problem fitting b6 sport on front and b8 sprint in the back? i own a 1979 320/6 and i want to get bilsteins all over with H&R springs! wich top mounts did you use?
E21noob
- My E21(s): SOLD
Re: Bilstein shocks
There is something not right here.
I went ahead and ordered Bilstein B8 front shock absorbers, but was dissappointed to receive a 39mm insert. Should be 45mm.
Not to say anything negative about www.hendyeshop.co.uk, but they do list B8's specifically for the 323. Front and rear.
Must say they have been helpful so far and can only hope they figure it out. From what I understand these lists come directly from Bilstein so could be the error is there.
Does anyone by chance have the part number for Bilstein B8 front insert? It is NOT 34-186350 as mentioned above and listed on their website.
Re: Bilstein shocks
As per their own on line catalog they have 1 model B8 front shock for all E21 which is the number you are referencing. Even though I'd prefer a tight fit myself as well the thinner one should fit allright and will be centered by the top nut.
