footwell speakers
Re: footwell speakers
Keen to do the same. Not removed my covers yet to see what's underneath. I'm guessing they're just a standard size that can be replaced. Good to get spen thoughts form other members though.
stock size is 10x15cm or 4x6" I believe. I have some Magnat's in there I believe. The size is a limitation but I wanted to stick to original size so it can hide neatly behind the original grill. Same size for front footwell and parcel shelf but many upgrade the latter to a bigger size. Useless in my case as most of the time it is covered by a folded down softtop. A small sub underneath your seat might do some magic perhaps?
- E21-driver
- My E21(s): BMW E21 315
Yes, that is right. Stock size is 4x6". There is a pair of Pioneers 3-way speakers available in that size or in 5x7". Search for them. They fit hardly under the stock cover, but it works.
What I also had in my e30 was a two-way compo system by Hertz. Excellent sound with separated highs. Just mounted them to the mirror triangles. The lows were located under the stock covers.
For the basses, I can recommend an active sub. I am using a Blaupunkt gt in the trunk of my e21. Sounds great, just for bass support, it is small and you don't see it in the interior.
1982 315 reseda
- croma_man
- My E21(s): '83 EU 327i
there is a trick also with the coaxial speakers to move the tweeters on a higher position. Mostly the center piece is removable, some soldering and longer wires and you can hide the tweeters in the upper part of the dash.
What is the max depth for the 4x6 speakers that fit under the stock cover?
E21 315 -82
VW Transporter T5 -10
EX: E60 545iA ///M-Sport -04
EX: E39 ///M5 -99
EX: E30 316i -88
EX: E36 325i -92
EX: E39 ///M5 -99
EX: E30 316i -88
EX: E36 325i -92
Depends on wether you have a original sunroof or not. The drainhose from the roof runs behind the speaker.
The original speakers are a tight fit, in case the hose is in place.
No sunroof.
E21 315 -82
EX: E39 ///M5 -99
EX: E30 316i -88
EX: E36 325i -92
EX: E39 ///M5 -99
EX: E30 316i -88
EX: E36 325i -92
steve5134
- My E21(s): 82 316
I've recently fitted Alpine SXE-4625S (Type E) in the front foot well of my E21.
4x6" 150 W
Fit in the stock position under the original speaker covers.
Not tested them in the car but tested them on the radio in the garage and there's a noticeable difference between these and the stock speakers
They're roughly £30 on ebay but I got mine from Road Radio for £35 (easier to return if they didn't fit but they did)
4x6" 150 W
