my injectors that are only a couple years old at the most are leaking and not opening at the same time.
i have flushed my injectors.
i pulled the poppet out wit a small wire very carefully, clamped a hose on the injector and back flushed it to get rid of anything in there, and they still leak just as bad.
i was very careful when putting the wire around the injector poppet to pull it out a little to flush them.
any ideas worth cleaning again or need new injectors
leaky injectors....
bimmerfane21
- Newbee
- My E21(s): 81 320i e21
Re: leaky injectors....
Probably the seals are pretty much dead after 35+ years of service. It's not cheap but replacing them with new ones is the only option left if a thorough and careful cleaning didn't help.
bimmerfane21
- Newbee
they are only a couple years old
Oh sorry for overlooking that! That is really weird. Puzzled as much as you are now!
bimmerfane21
- Newbee
Shameful. Ill keep trying to adjust mixture screw slowly and dist to get it going again as from previous post. Hoping to get her to start again
