Hi guys,
I need to get 2 new bolts that hold the drums in place and not sure what size they are. Real OEM isn't very clear, was hoping someone would know!
Thanks
316 Brake Drum Retaining Bolt
- wigmanreturns
- Newbee
- My E21(s): '83 UK 316 Manual
Re: 316 Brake Drum Retaining Bolt
And NLA from the dealer? That would be the easiest way imo
healeyneil
- My E21(s): '81 318is Baur - ahead of its time !
Theyre not standard bolts. A pan head socket head is how Id describe it. From memory the thread size is about the same as a 10mm bolt.
- polov8
Is it one of these?....
Or one of these?....
Pics found using "E21 disc retaining screw" as a search on google.
Andy
Yup that's for brake discs and therefore is likely to be different. Can't find it on realoem. Wanted to check with my dealer contact but he's currently testing new Mini's in Morocco. Thought I had a tough life...
- wigmanreturns
- Newbee
Yeah, I checked with my local BMW dealer and it still wasn't very clear, he said he could see 3 bolts available. Looks more like the first one, thanks for the help.
Just order one for an e30 and it will be fine!
