Protecting the Oil Pressure Switch Cable 323i
e21Keith
My E21(s): '81 323i Manual
Post by e21Keith »
The wire for the oil pressure switch just seems to route loose around the front of the timing belt cover on the e21 and seems really easy to damage, actually both engine looms I have are damaged here.
The e30 has a plastic conduit for this wire but it doesn't fit the e21, does anyone have a reliable method of protecting this cable from damage by the water pump pullet etc?
Re: Protecting the Oil Pressure Switch Cable 323i
It Actually runs behind the cover, behind the rubber flap, there is a cavity where it should go. Then nice and tidy around the corner, through the plastic clamp in the hole on the corner and straight to the switch.
Same on the e30 m20 by the way
See cable going behind the cover. This is my e30 325i but all the same with a e21 323i.
e21Keith
Post by e21Keith »
I'm thinking about the M40 which has a plastic channel.
Thanks for the photo, none of the others on the web showed this and it's not the way mine came apart
Agree, most times you see the cable being run over the timing belt cover and the M40 has a cover for the cable indeed.
