BB-Carworks 323 S-Edition restauration
Re: BB-Carworks 323 S-Edition restauration
Yeah great milestone, congrats!
BuschBertl
My E21(s): 323i S-Edition E21, 325i E30, M3 E46
Post by BuschBertl »
That´s the nicest job of all! Inserted the shiftig arm with new support brackets and did some small installations like mounting the starter.....!
There is one problem. I´ve been testing the universal joint on the transmission. There is very low space between the universal joint (Hardy?!) an the srews arround :nah
Maybe it is the wrong universal joint?!?
BB-Carworks
BMW E21 323i S-Edition 1982
BMW E30 325i Cabrio 1991
BMW F87N M2 Competition 2018
I see 2 things.
1. That hardydisc is a Meyle product. I will never ever use a Meyle product again. It is a inferior brand, and their rubber products are not that durable. I would order one at BMW. Little mounts on the shiftplate are mounted correct, as far as I can see. That disc looks a bit big indeed.
2. The bolts used on the vibration damper, are the new? Or rezinced? I used ones that are re zincplated, but they came off. So I ordered new ones at BMW. They have to be 10.9, not 8.8. Just make sure to have the 10.9 ones and use sufficient locktite.
By the way, don't you have powersteering?? I see that the pully is not on there, that is why I am asking.
BuschBertl
Thanks for the Tipps! No i haven‘t powersteering! The screws are new but Not from BMW. I will change them After your Input! Also the hardy! Thanks
BB-Carworks
Yup defo dish that hardy, Meyle are the biggest rubbish one can buy indeed.
BuschBertl
Got it from W&N :-(
Buy a new OEM
BB-Carworks
I got the same from WN and first found the next drive... had to take it all apart again and it rubbed the shifter rod, it has been leaking oil ever since, even after repkacing the seal grrrrr. Thanks Meyle and Walloth.
BuschBertl
Part after part..... :smoke
BB-Carworks
Looks sooooo great!!! Just over a year ago I was there. Reliving it all. Thanks!
Looks great again.
Such cute 'n clean stuff!
BuschBertl
I forgot to check my additional air slide valve. So i dissambled it again. It was very dirty inside. So i cleaned and oiled it. After i built it together i did a test with boiling water. It didn´t move any millimeter! :protest
I can´t get a new one so i am now searching a secondhand one! :nah :wtf
After some swear words i rebuilt the generator:
I am not sure where the wires have to plug in :nah
BB-Carworks
To bad for that airslide.... dynamo came out great.
wire goes on spade connector with red circle (marked D+), spade connector with green circle is for the capacitor (marked +), very nice work
see my left alternator/generator/dynamo:
BuschBertl
I dont have this capacitor?!? Hm?!?
BB-Carworks
