e21 project
Re: e21 project
Hello,
Long overdue update.
So the complete under carriage and wheel arches underseal and paint was stripped back to bare metal in sections and then sprayed with expoxy primer. this was was also done in the engine bay, boot and on the inside.
Re: e21 project
The undercarriage has been re sealed with 3M grey underseal and painted alpinweiB 146/0 along with the engine bay, boot and inside.
Re: e21 project
I then started to work on the doors, bonnet, boot and the shell. I used Parimose paint stripper to remove the paint and 320 sanding discs on the metal. I had to send the bonnet off to a company (Envirostip) in Birmingham to help with the rust removal as it was too labour intensive to remove it all by hand. I then got a couple of car body work guys to come and do any filler work where required
Re: e21 project
Whilst the guys were doing the body work, it gave me a chance to have a look at some of the other parts that would need attention.
The sound insulation for the engine bay was for a left hand drive car so I needed to fit this, cut out the section required for my car and fill in the blank space. The wiring loom needed to be redone. The window trim needs attention I could not tell if it had some type of coating over the aluminium but I used 320 sand paper and worked down to 1200 wet and dry then used polishing compound with a sisal and buffing mop on a bench polisher. I have left a piece in the garden to see if it oxidises but it seems to be holding up quite well so far so I don't think I will be applying a clear coat over the trim pieces. I have also heard that it is quite hard to get clear coat to adhere to high polished metals. The brake, fuel lines and some nuts/bolts were cleaned, primed and sprayed black Lastly the rain flooded my shed and the seats were on the floor so they got completely soaked. I had to use a an upholstery cleaning machine to try and salvage them. The back seat still has a water patch but this was there when I got the car. Will give it another go before I am ready to fit them.
anastasio
- My E21(s): 1982 alpina c1 2.3
Re: e21 project
WOW....great job, it will be like NEW !!!
Re: e21 project
Impressive job being done here, respect indeed, and thanks for sharing! Keep us posted on your further progress!
TaylorGoesFast
- My E21(s): 83 320i, 95 325i Spec 3 Race Car
Re: e21 project
Really great work! This will be a new car!
2011 F150
1995 BMW 325i Spec 3 Race Car
2008 BMW 128i 6 Speed Sport Package
1983 BMW 320i
2005 Kinetic SC
1983 BMW 320i
2005 Kinetic SC
- BuschBertl
- My E21(s): 323i S-Edition E21, 325i E30, M3 E46
Re: e21 project
Awesome work - One more nice new e21 is coming!!!
BB-Carworks
BMW E21 323i S-Edition 1982
BMW E30 325i Cabrio 1991
BMW F87N M2 Competition 2018
