Hi Everyone,
I'm at a bit of a road block after i need to replace my Brake pressure regulator, part number 34331116365 due it leaking, and my garage and i cannot find a direct replacement. Please can I have some advice about how to deal with the problem?
Hardeman motorsport sell this part, would this be a replacement for this part?
https://www.motorsportparts.nl/opel/ast ... -draaiknop
Any knowledge would be greatly appreciated.
Thank you very much
regards
Matt
316 Brake compensator/pressure regulator
mjeffrey21
- Newbee
- My E21(s): 77 316 manual
Re: 316 Brake compensator/pressure regulator
Hi Matt, I believe this is more or less a brake pressure limiter, limiting the amount of pressure going to the rear wheels to prevent instability or a unwanted F/R brake balance. I believe these are NLA for quite some time. If you've confirmed the unit is actually leaking and it's not one of the brake line connections, a manual brake pressure adjuster like the one you've referenced could be an option indeed.
