It turns out that I am either a massive "absolute unit"... Or the seat mechanism is broken. If it's the former I noticed that I had plenty of adjustment room when the right toothed seat forward back adjuster was not installed (I had to replace the seat standoffs). It felt solid ish, and would be solid up and down, do y'all think it's safe to only have lock on one side? For context this is the gymnastics I have to do to get my foot over the brake; in addition I am 6'3 or 195ish cm and have my ass to the back of the chair.
edit-fixed embed
Ok so I looked and it appears both are at the end of their respective tracks... Should I just buy a seat that's lower down and so forth? For now I guess I can work around it.
edit- Found out there are "long" seat rails however they are few and far between, and that they are for 78 and on whilst my car is an early model...
I'm 1.85 and I struggle myself sometimes. Got around it by swapping my steering wheel for q 3 spoke. It worth gave me more room. You can also get lower seats, but try measuring your wheels diameter and find some 3 spoke or after market and compare. 10 or 20mm make huge difference
Leinho wrote: Fri May 03, 2024 4:21 pm
Yeah I will try looking into this first, just a bit more clearance and I will be good. I'm planning on upgrading to a bucket seat at some point anyways however as I would like to see how this car does on the touge. Thanks for your input, now to see how a smaller steering wheel will treat me.
