On board computer
7800rpm
On board computer
Post by 7800rpm »
I'm buying an obc to fit in my 320is...
...it's good looking and can be useful but...
do you know if it's a plug and play item or it needs special plugs and connections?
obc is from e30 325
thanks
[img]http://www.thefilebin.com/userfiles/7800rpm/320is/Sign.jpg[/img]
It's almost plug and play... you have to change the code plug in the rear of the OBC unit if you have the large unit with fuel consumption and all. In that way the OBC knows you're running a S14 with a different gearbox and diff! That plug is still available from the dealer.
Consists of: control unit, OBC dash unit (the one with the buttons), cables between OBC and control unit and between OBC and instrument cluster, gong and cable, outside temp sensor and optional the lever on the steering column and cruise control unit.
If you're talking about the small OBC... that's just clock, date and outside temp, no code plug required.
Consists of: dash unit, cable between instrument cluster and OBC, gong and cable, temp sensor and cable.
Hope I didn't forget anything!
7800rpm
Re:...
Post by 7800rpm »
Hi Jeroen, i'm talkin about this
Yeah ok I believe it's called the OBC II, the large unit. As you can see in my previous post you need quite a bit of additional stuff otherwise it won't work.
BTW there are several different versions... I wouldn't go for the US Miles/MPG version but for a Euro metric unit.
7800rpm
Post by 7800rpm »
Jeroen thanks for the fast and accurate reply.
I hope there is a way to change mph in kmh ang mpg in km/l
Do you think all the stuff is expensive?
Worth the money?
We can buy Greddy full auto timer for 55€ on ebay
No idea if you can switch from miles to kms!
Complete sets go for abt 100-150 Euro I believe.
And worth the money... I would only have it for the looks as I won't even be interested in the fuel consumption of my 320iS. Fuel consumption is quite good actually but I have that machine to go fast no matter the fuel economy. So I guess I just won't use functions like that... the only thing I really appreciate is a ice-warning and that's just what my OBC I provides... so an OBC II isn't worth anything to me...
7800rpm
Post by 7800rpm »
Infact it's especially for the look that i intended to buy the obd2...i've found it on ebay at about 5€ so...
...but i was thinking to buy a greddy full auto meter...
with this you can also check your instant and max speed and the acceleration 0-100kmh 0-200kmh 0-400m
rotaxmaxke
Post by rotaxmaxke »
[quote="Jeroen"]It's almost plug and play... you have to change the code plug in the rear of the OBC unit if you have the large unit with fuel consumption and all. In that way the OBC knows you're running a S14 with a different gearbox and diff! That plug is still available from the dealer.
quote]
Hey Jeroen,
I have also an large unit for my "is"
What do you mean by "code plug" :roll:
Have you got a picture of it?
a proud 320is owner
No pic here at the moment. It is a small unit that plugs into the back of the dash unit of the OBC.
france320isco
a enricoooo
Post by france320isco »
ma buttala queamachina
rotaxmaxke
Jeroen wrote:No pic here at the moment. It is a small unit that plugs into the back of the dash unit of the OBC.
This white thing ? :o
For which engine is this one ? :?
a proud 320is owner
That's the one!
The one you have (1 376 032) is for E30 320i/323i... that won't work properly.
You need the 1 385 936 (320iS) and maybe the one from the stock Euro M3 will work as well: 1 380 891.
Please note that a new one costs € 32,50 at the dealer. Finding one used might be difficult...
hardtailer
Post by hardtailer »
Code plug from the E30 M3 won't work properly as it 's fuel tank capacity is dífferent. That will definately affect the range reading and probably the fuel consumption numbers also as calculating it using only injector opening time is not accurate enough to be useful.
rotaxmaxke
thanks :wink:
Any idea what the arrow switch is for? (30 - 60 - ch30 - ch60)
a proud 320is owner
