Pads for wilwood powerlites
Have you contacted Greenstuff and asked? They might be interested if you can send a pattern?
Morris
Post by Morris »
When you guys say Mintex, are you talking about standard Mintex Pads, or the racing pads M material pads they do?
I only ask, because I have an account with Mintex but dropped them last yr and moved to delphi lockheed.
In my experience Mintex is a well known brand, but not neccesarily the best pads on the market (as everyone thinks)
I currently sell delphi lockheed and i think these are superior to mintex in quality.
In my opinion the best quality pads to buy on the aftermarket are TRW Lucas.
This is what I fit on my e21 anyway.
(im just talking about standard pads - not racing materials as I dont have experience with these e.g. ebc etc)
Madhatter
Post by Madhatter »
obviously not talking OEM replacement pads (and compounds).
drjim
Post by drjim »
If anyone who does trackdays is thinking of using the wilwood fast road pads - DON'T!
Just had new clutch fitted to my car (release bearing grumbling and pressure plate playing up - 20 quid ebay clutch kit fitted initially, now has a proper one). Got my mechanic to check the brake pads and change as necessary while it was on the ramp.
Pads were down to 0.5mm apart from one that was almost on the backing plate.
They had done one trackday at Oulton and about 30-40 road miles.
The brake fluid reservoir for the front circuit was almost empty - it was all in the calipers!
Discs are as new, no noticeable wear, have fitted Wilwood race pads now, see how they go on at Croft
Jim
1982 Saphirblau Baur 325i
Cars all gone!
Duracel79
Re: Pads for wilwood powerlites
Post by Duracel79 »
I've just ordered some more EBC Yellow pads for my Powerlites.
This site are still offering this forum the 15% discount:
Hi
We would be very pleased to offer your forum users a 15% total discount.
This would be by means of a promo code to use online only.
Once you have finished selecting your items and are viewing the cart contents, please enter
BMWE21HY79767
into the promo code field for the discounts mentioned. The code is tested and working.
Regards
EBC Brakes Direct Limited
http://www.ebcbrakesdirect.com
Office opening hours Monday to Friday, 9am to 5pm
EBC Brakes Direct is an independent company and not owned or operated by EBC Brakes nor Freeman Automotive.
We are a master distributor for their products.
(PLEASE REPLY WITH HISTORY ON ALL EMAIL COMMUNICATION)
Cheers
Ben
Jason_323i
Post by Jason_323i »
ds2500 ferdo swaped to them on the m3 not cheap but the biggest single effect on braking and have a very good wear rate
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Jason you dont happen to know the part number for the ds2500 pads do you?
edit -
actually i think i found them ??
http://www.camskill.co.uk/products.php? ... 4056p53546
im pretty sure that you can use these on the road as only cars made after end of 1999 have to be reg 90 certified.
classic car 1 - modern rubbish 0 lol.
Jason_323i
Also they do work better with heat, compared to cold
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
r1nod
Post by r1nod »
haven,t been on here for a while where did you get the calipers and how much were they did they come with brackets thanks
