Pads for wilwood powerlites
drjim
Post by drjim »
Many of us bought wilwood powerlite calipers as aprt of the groupbuy last year. I got the fast road pads with mine.
From the amount of brake dust on my front wheels, the amount the front circuit fluid reservoir has dropped, and a glimpse through the wheel of the pads (not got round to taking a wheel off since Oulton in Feb!), I suspect I have eaten a set of fast road pads in a day.
The options seem to be Wilwood race pads or Mintex.
Anyone have any opinions/advice on what to get as an upgrade. Fast road jobbies stopped the car very well, but appear to have worn out!
Jim
1982 Saphirblau Baur 325i
Cars all gone!
Duracel79
Post by Duracel79 »
My wilwood race pads are lasting well but i've not been on track yet to punish them.
however the dust they produce will not come off the wheels even with t-cut.
i'm be changing back to Mintex before refurbing the wheels.
Ben
Madhatter
Post by Madhatter »
make sure nothing is sticking first.
Can try the "C" series pads from wilwood, probably the best wear rate. Otherwise, give these guys a call (or email) http://www.cobaltfriction.com/
Ben, the more aggressive pads will strip clear coat and chrome off wheels, so you need to clean them after racing right away otherwise they are known to etch the surface of your wheels. Probably find thats what has happened to you.
cdavie2002
Post by cdavie2002 »
If its making a mess of the wheels, how grubby are the actual calipers?
Iv got wilwoods, just not fitted yet. Can someone tell me which pads are recomended for road use, and if they are going to make a mess or not?
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
tommi_e21
Post by tommi_e21 »
Not that i know if they make them for wilwoods but EBC do good brakes with a vareity of levels of grip and all fairly low on the ol brake dust.
dannyboy
Post by dannyboy »
i have ebc green stuff pads, they always seemed ok.. 8)
e21 335i gone but not to far.
e21 316.. still
ford puma..(wifes honestly)
Madhatter
Post by Madhatter »
E series isnt bad on the road, not too dusty and wont destroy your wheels. If you get them real hot they will fade though, but shouldnt find that point on the road.
Ive got B series pads for the track which are brilliant, they are much harsher on rotors though and you really, really need to make sure you cool down the pad/rotor when you finish your laps. Do a slow out lap or try and drive around the pit area a bit, allow them to cool down, dont just park the car and walk away.
murran
Post by murran »
Madhatter wrote:really need to make sure you cool down the pad/rotor when you finish your laps. Do a slow out lap or try and drive around the pit area a bit, allow them to cool down, dont just park the car and walk away.
agreed the heat will soak into the caliper thru the pads, not doing the brake fluid any favours. the cooling effect of this on the part of the disc where the pads are may well warp the disc too.
the pads that we got with the calipers in the group buy seem ok to me. I havent had a problem shifting the dust off.. but then i do polish the shit out of my car / give it a wash regular.
pistonheader
Post by pistonheader »
nas80 wrote:the pads that we got with the calipers in the group buy seem ok to me. I havent had a problem shifting the dust off.. but then i do polish the shit out of my car / give it a wash regular.
shouldn't polish your car more than a couple of times a year 8) unless you just use a filler polish like super resin polish by autoglym? polish takes tiny amounts of paint.
usually i just wash and wax mine, polish once a year :)
use this sealant twice a year, once just before winter hits....it's amazing stuff. it's still on after 6 months through winter, protects the paint really well.....
http://www.cleanyourcar.co.uk/sealants/ ... d_355.html
follow up with this wax
http://www.cleanyourcar.co.uk/wax/colli ... d_207.html
and your paint will be very well protected from UV, bird shit and so on, and the water beads really well 8)
damn i'm sad :lol:
murran
Post by murran »
when mine gets dirty i wash it..... gets dirty again i.......... you get the idea! :lol:
pistonheader
murran wrote:when mine gets dirty i wash it..... gets dirty again i.......... you get the idea! :lol:
is yours a daily driver murran? if you seal and wax it, it makes cleaning much easier in the future!! but yes, it's a pain in the ass to do. but, mine being a daily, i'd like to keep the paint work nice, until i can afford a bare metal respray 8)
Try wheel guard from www.spautopia.co.uk - it's excellent stuff. Far better than the usual stuff like RimWax etc. Mention the e21 forum and you might even get a bit of a discount? ;)
Madhatter
Post by Madhatter »
It does warp the rotor, bad thing if you dont have floating calipers because it will highlight the warp/thickness variation, giving you shake in the steering wheel/ pulsating brake pedal.
Duracel79
Post by Duracel79 »
Madhatter wrote:make sure nothing is sticking first.
Yeah, does look like its bonded to the new paint that was on the wheels.
Using the car regularly on the road at the moment, so cleaning after every journey would be a pita.
Gotta do some real track work to wear them out, then fit less dusty pads. Then I can repaint the wheels.
The last set of EBC yellows I had worked well and the dust was manageable, but you can't get them for powerlite calipers :(
Looks as if Mintex is the only other option, although they are more expensive. :roll:
Ben
