1983 BMW 320i
Happy_Dan
My E21(s): 1983 E21 5 Speed manual
Re: 1983 BMW 320i
Post by Happy_Dan »
Thank you again. I have been searching all around the other forums and this one. There is a lot about these switches. I think I have the problem with the spring and the plastic piece that holds it in. So even if I fix the detent, the spring may cause a short. I think I will try the jumper to see of I can get the blinkers working while I wait on a switch. I will post in the marketplace.
Happy_Dan
Re: 1983 BMW 320i
Post by Happy_Dan »
I was able to remove the spring and fix the detent. My switch is now working and blinkers are working. I will not be using the flashers so I will just leave it pushed in! No need to push my luck with that.
Re: 1983 BMW 320i
:thumbsup :thumbsup :thumbsup :thumbsup :thumbsup
Re: 1983 BMW 320i
So now you're a Happy Dan!
Happy_Dan
Re: 1983 BMW 320i
Post by Happy_Dan »
Just a quick update!
The car is registered and on the road. I will take it for its first ride tomorrow. Hopefully it will get me home. :)
I did replace water pump and some of the hoses.
I am still fighting with the heater valve that I replaces. I am having a hard time getting the cable in and held with the clip. The valve seems to close to the bottom heater core hose and when I twist it a bit to get the hose on, the cable clip pops off. For now, I just have it connected without the clip and manually move the lever when I want heat. Not a very good design in my opinion.
Thanks to the forum, I have done a lot of reading here and incorporated much of what I learned into the project.
Re: 1983 BMW 320i
:thumbsup fingers crossed for a lovely ride tomorrow Dan!
and for the heater controls... yup, horrible design and now the plastic is ageing, you may need to be a bit creative with tie wraps and superglue haha
Re: 1983 BMW 320i
Have a great first trip!!
