Recognising 5 speed gearboxes
- BMW-POWER
Re: How do you recognise a sport 5-gearbox
anyone else to confirm this?
E10 2002tii 73'
E21 320/6 78' Anthrazitgrau
E30 325i 86' Diamantschwarz
E30 325iC 89' Diamantschwarz
E36 320iC 94' Dunkelblau
E87 118d 05' Havanna
- --ALPINA--
whats there to confirm? i have a 5 speed box like the picture youve posted in my garage and dogleg gear box on my car the way i stated the switch being on the back of the prop shaft end. as mark (retrobeemer) says, simplesBMW-POWER wrote:anyone else to confirm this?![]()
--ALPINA-- wrote:whats there to confirm? i have a 5 speed box like the picture youve posted in my garage and dogleg gear box on my car the way i stated the switch being on the back of the prop shaft end. as mark (retrobeemer) says, simplesBMW-POWER wrote:anyone else to confirm this?![]()
Unfortunatly alpina, your genral sarcasm (although funny) makes everyone not believe a word that comes out of your mouth with out confirmation from others,
Audi 50 RS
Audi 50 RS
- --ALPINA--
To be honest motronic tommi what it is, if i know something for sure i would tell the truth to be honest, otherwise ill take the piss deliberatly out of anyone but wouldnt disrespect all in good jest.austin25uk wrote:--ALPINA-- wrote:whats there to confirm? i have a 5 speed box like the picture youve posted in my garage and dogleg gear box on my car the way i stated the switch being on the back of the prop shaft end. as mark (retrobeemer) says, simplesBMW-POWER wrote:anyone else to confirm this?![]()
J
- Mcinek
- My E21(s): '80 BMW 323i
Does anybody know what is the BMW part number of the gear selector I marked on the pic below.
BMW "Freude am Fahren"
Marcin
Marcin
For the 245/10 or /11 M20 dogleg that partno should be 2331 1 539 086 should cost abt € 7, don't forget to replace the oil seal.
- Mcinek
Thanks a lot Jeroen, you're a huge help. Do you also know the part number for the 242 5 speed dogleg. I'm bit confused which box I have, 242 or 245.
Thanks you.
Thanks you.
Marcin
Marcin
Marcin, as described in the whole topic, the 242 cover might also be fitted to a 245, 242 is the 4 speeds short gearbox. For the 4 speed the part no is 2331 1 206 981.
MeesterPieter
is the front gearbox cover from the 5-dogleg replacable by a cover from a 4-speed? (the front part of the gearbox)
since my dogleg has a hole and some deep slidmarks from something i guess has been a blown clutch..
the marking says 242, but according to ETK the cover from the dogleg-5 is not the same as the 4-speed cover...
[url=http://www.e30forum.nl/forum/viewtopic.php?f=31&t=94][img]http://i37.photobucket.com/albums/e79/MeesterPieter1/divers/sig2copy.jpg[/img][/url]
- Mcinek
Jeroen wrote:For the 245/10 or /11 M20 dogleg that partno should be 2331 1 539 086 should cost abt € 7, don't forget to replace the oil seal.
Jeroen after checking the partno I belive it should be 2331 7 539 086. Can you please confirm.
Marcin
Marcin
Marcin
I can't remember where (getting older) but i have read somewhere that if the number on the bellhouse ends with GG it's an overdrive box.
And if the number ends with GC it's a sport box. (not officially confirmed)
Checked on two of my ECO boxes and they both end with GG.
When i really have nothing to do i will remove my sports box and check the number for you guys.....
- Blackadder
Re:
Question, what's the difference in lenght between a driveshaft 6 cilinder 4 speed, and the driveshaft 6 cilinder 5 speed eco?ronaldo wrote:Hereby another picture of the diff. between the shafts![]()
I will change my automatic gearbox to 5speed eco. I will have a look on the market for a drive shaft 6 cilinder 4 speed and shorten it.
inches and cm please...
- Blackadder
Re: Recognising 5 speed gearboxes
Could be.....
If the drive shaft of a 5 speed sport = 5 speed eco....
Also check the Dutch topic, I measured a difference between 4 sp and 5 sp overdrive of 2.9" and Pierre's site came up with 3.1". There are 2 M20 sports boxes and one is exactly the same length as the eco box (I know for sure as I had one that was the same length). That .2" or 4mm prolly is something that can be caught in fitting the diff but some others' measurements would be welcome! I have the right propshaft for you (4 sp 4 lug) if you want to make one custom fit.
