my 316 m52 swap
joe14
My E21(s): 1983 black 316
Re: my 316 m52 swap
Post by joe14 »
Really nice!!
Gavin Martin
My E21(s): '81 316 - '80 320/6
Re: my 316 m52 swap
Post by Gavin Martin »
Thanks fellas :) my dad has been working he's butt off on this for me with regards to the paintwork ect (Retired panel beater) so I can only take a little credit for it ;)
I made a bit of a cock up with regards to the powder coating bits - they were supposed to be satin and come back gloss (brake assembly, scuttle panel & anti roll bar) but decided I quite like it so did the servo and master cylinder to match :thumbsup. Brake pipes and clutch pipes to be made tomorrow, refit the wings and front panel & bumper then I can start thinking about fitting the engine- although this will now have to match the cleanliness of everything else that's been done. This just chuck an m52 in has gone a bit far but hopefully worth it in the long run lol
Gavin Martin
Re: my 316 m52 swap
Bit of a slow progress day today, but it nearly has its pretty face back :boogie
Gavin Martin
Re: my 316 m52 swap
Gavin Martin
Re: my 316 m52 swap
So today we got most of the brake pipes made, and fitted up the the grill
Gavin Martin
Re: my 316 m52 swap
Before
After :)
Gavin Martin
Re: my 316 m52 swap
Re: my 316 m52 swap
Nice and clean!! Keep up this good work!!
Gavin Martin
Re: my 316 m52 swap
Some nice new shiny bits arrived today ;) i purchased these from tengu drift on Facebook, they were able to get the spring rates I wanted and they were about £80 cheaper than anywhere else I looked - highly recommended them and their services
Re: my 316 m52 swap
:banana Screwy!!!
:thumbsup
Gavin Martin
Re: my 316 m52 swap
Got a few more bits back from the powder coaters :) so managed to get the rack cleaned and put back together with new rubbers. Just waiting for new gaitors to arrive and that's another job ticked off the list
Moutinho
My E21(s): ´79 Euro 320/6 5speed Manual
Re: my 316 m52 swap
Post by Moutinho »
did you get poly bushes for the steering rack?
that is clean like hell!!! i´m also doing a m52b28 swap in my 1979 320/6, but i´m in the process of get all the bits!
wish mine will look like that! great work :thumbsup
Gavin Martin
Re: my 316 m52 swap
Thank you - it's starting to come together now :) I've gone for standard ones for now, but will upgrade to poly later in the year - I'm going to put a quick rack in as soon as funds allow.
Have you already started your swap?
Moutinho
Re: my 316 m52 swap
Post by Moutinho »
Nop, i´m after all the pieces, like the m50b25 sump and intake and the engine it self, lool... Where are you going to get the quick rack, and how much did it cost?
Did you fabricate the engine mounts? My mechanic says that m30b35 e28 engine mounts should fit without major mods...
Gavin Martin
Re: my 316 m52 swap
Sourcing the parts took me a while too, the steering rack has not been purchased yet and I'm not sure on the cost but there is a company in the UK that does them apparently. Soon as funds allow I will investigate further. As for the engine mounts I have used the alloy mounts from the m20 with standard (new) m20 rubber mounts, the engine will be going in very soon so will be able to report on the success of this set up ;)
