my 316 m52 swap
Gavin Martin
My E21(s): '81 316 - '80 320/6
my 316 m52 swap
Post by Gavin Martin »
Gavin Martin
Re: my 316 m52 swap
shopping list so far
6cly subframe
320/6 5 speed
320/6 flywheel
e30 325 clutch
320/6 release bearing
320/6 propshaft
320/6 diff
all new engine and gearbox mounts
modded m50 sump (thank you nas)
m52 b28 engine
modified ecu
e30 318is fuel pump
323i rear trailing arms
Wildwood dynalight 4 pot....
I have a feeling there will be plenty more to add to list as we go
steve5134
My E21(s): 82 316
Re: my 316 m52 swap
Post by steve5134 »
Lol... Looks like mine does at the moment :)
Good luck with all your plans that you have for her
Gavin Martin
Re: my 316 m52 swap
thanks mate! this has to finished before the arrival of our next baby in January! I've had some very helpful advice from mcjordan and nas so hopefully my pre prep work should have this done fairly quickly. I saw you were looking for an m50/m52 I presume you are doing the same?
steve5134
My E21(s): 82 316
Re: my 316 m52 swap
Post by steve5134 »
Yes mate I'm doing the same. I've arranged the engine (m52 2.8 ) but not at my garage yet, when it is I hope to get a move on with mine too.
I've got three young kids so know what you mean about time restraints :lol:
Keep us posted with how you get on :thumbsup
Re: my 316 m52 swap
Gavin Martin wrote:shopping list so far
6cly subframe
320/6 5 speed
320/6 flywheel
e30 325 clutch
320/6 propshaft
320/6 diff
m52 b28 engine
modified ecu
e30 318is fuel pump
Make sure you swap the m20 gearbox pilot bearing into the back of your m52 at the same time.
Gavin Martin
Re: my 316 m52 swap
Thanks nas, I had already swapped that - just forgot it off my list ;) any news on the sump? Going to hopefully get the bay painted this weekend and then it will be time to start peicing it all back together
E21noob
My E21(s): SOLD
Re: my 316 m52 swap
Post by E21noob »
Cool. Look forward to following as you progress.
nas80 wrote: Make sure you swap the m20 gearbox pilot bearing into the back of your m52 at the same time.
Isn't this the same on M10, M20 and M30 engines? Part number 11211276551?
joe14
My E21(s): 1983 black 316
Re: my 316 m52 swap
Post by joe14 »
This should be good when it's all finished.
I'm doing an M42 conversion and also require the E30 318is fuel pump.
Its proving hard to find, any alternatives available??
Gavin Martin
Re: my 316 m52 swap
I went on e30zone on Facebook and put a wanted comment up for the pump, and got one within 20 minutes :) I was looking at the m42, then a friend had a little accident in he's 328 hence going this route. I should think the m42 would be a really nice balance in a 21. Good luck with your build
joe14
Re: my 316 m52 swap
Post by joe14 »
Oh well, it's good that something has come out of their 'little accident'
Cheers!
Gavin Martin
Re: my 316 m52 swap
bit of an update... i got my sump back from nas (thanks mate). I had a bit of a drama with the oil pick up pipe as it broke in two just before i was about to fit it, luckily it happened in my hand an not in the engine. just looking at the original steel m52 pick as it is steel and easier for me to get modified???? not sure if this has been done, but looks like an option.
After stripping the complete fron end off the car i realised it had some minor damage on the front panel from a previous accident, so this has now been put right and any rust removed and is nearly ready for paint, so all being well should have it ready soon to fit the engine :)
Re: my 316 m52 swap
:thumbsup
Any pics? :takepicture :wink:
Re: my 316 m52 swap
Yes please!
Gavin Martin
Re: my 316 m52 swap
