Just thought I would share with you my restoration project.
I took the car up to the mechanic over the weekend who's going to be carrying out the welding work for me. As you can see there's a bit of cosmetic welding required but he assured me he has worked on far poorer examples before.
http://s1034.photobucket.com/albums/a429/Jokercooper/
The welding work that's getting carried out is:
Small hole inside the boot below the fuel pipe. Apart from that the whole boot is fine.
Both rear wheel arches.
Both side seals, inside seals are both fine so that was a relief!
Replacement front wings &
The panel that holds the front light in place, don't know the name sorry... that is prob the worst part of the car.
Once the body work is completed I'm onto the internal bits. I'm changing the track rod ends as their a bit worn. Bleeding the radiator and fixing the binding brakes.
After all the other bits and pieces are finished she's getting a lovely coat of fresh paint, freshly polished bumpers and wheels and to finish her off I'm going to get some beautiful new BMW badges.
I'll add more pics each weekend as I go along...
