Indicators and wipers stopped working
HaroldShand
Post by HaroldShand »
Hi people, can you help me please ?
Indicators and wipers have stopped working, out of the blue. Both were working fine yesterday. Hazards work ok.
Could this just be a fuse or is it likely to be something more sinister ?
I'm at all mechanically able so any advice you could give would be much appreciated. I've just moved to a new town (Leeds) and am grounded without my daily driver !
Thank you for our interest,
H
indeed the wipers and indicators are located under one fuse.
Try to look at the fuse number 15. Probably yoúr horn and windscreenwash wil not be functional also. The fuse can be OK but the E21 is very sensitive at the fusebox for corrosion. Clean up the fuseholder and it will be OK.
Kpeters
Post by Kpeters »
It's the fuse, if it keeps blowing then it is probably the wiper relay that thing sucks.
My 1981 Kastanien Rot 327 [url]http://www.bmwe21.net/forum/viewtopic.php?t=789[/url]
2002 71"
HaroldShand
Fault traced
Thanks guys, turned out to be the recently replaced hazard warning switch that was shorting when off, blowing the fuse as you suggested.
Another triumph of the helpful e21.net forum !
Thanks again, H
Kpeters
Re: Fault traced
Post by Kpeters »
HaroldShand wrote:Thanks guys, turned out to be the recently replaced hazard warning switch that was shorting when off, blowing the fuse as you suggested.
Thanks again, H
Ahhh...the switch that's another P.I.T.A :D
My red cap on it has to be screwed only half way for it to lit up at night lol.
2002 71"
