Access to Articles section
bmwe21.net has a nice "E21 articles" section at the bottom of the first forum section (E21 forums - english section). This section is filled with magazine article scans from all across the globe (feel free to add new scans).
To avoid any copyright issues with BMW or with publishers, this section has limited access.
By registering with a special user group called "E21 fanatics" your application will then be reviewed by the moderators and access is likely to be granted on short term.
How to get access:
1. make sure you are a registered forum member and logged in
2. select the "E21 fanatics" group in your User Control Panel
3. click 'submit' at the right bottom of the page
4. usually you will have access within 24 hours
By submitting you declare that you understand that you're accessing copyrighted third party material and that you will not share this information with others.
