not to sure what this is
brendan320i
My E21(s): 1983 320is 5 speed
Post by brendan320i »
can someone help me out here and tell me what this plugis for? im guessing whatever is missing is preventing my car from starting..Image
1983 bmw 320i
1991 volkswagen jetta 1.6td mk2
Re: not to sure what this is
Nope, nothing wrong or disconnected, just a diagnostics socket.
brendan320i
thanks, im really puzzled as to why theres no spark or fuel, i bought a new coil today, still nothing.dist cap and rotor are new.
1983 bmw 320i
cdavie2002
Post by cdavie2002 »
Im sure someone on here can identify your starting issues.
Out of interest does anyone know what info that plug can actually provide?
Chris
1982 320/6 (breaker)
1975 3.0 csi
1974 3.0 csi (donor)
2003 E46
brendan320i
apparently it just picks up bad o2 sensors and when your oil needs changing?
1983 bmw 320i
mr edd
Post by mr edd »
from what i have read the fuel pump will only run if the ignition is working as there is a connection from the ignition module to the fuel pump relay ... if you need a wireing diagram i have one for a american spec 320i 81-83 that i could email to you !
e21 316 (1981) TRE702X.
Take the fuel line off under the bonnet and check you've got fuel supply / pressure.
