Fuel pump for 2.5i conversion
Millar
Post by Millar »
I'm replacing the 2l carb in my 320/6 with a 2.5i and was wondering what i'll have to do about the fuel pump. I take it i'll have to change to an electric fuel pump. If so any recommendations on what one to get and how to go about doing it?
Cheers
Millar
drjim
Re: Fuel pump for 2.5i conversion
Post by drjim »
I run the slugs efi off an e30 318is in tank pump which fits perfectly although the sender is wonky so the fuel gauge reads wrong. I have another one that I will probably use on the Baur, it's basically the same pump as on a 325i so will flow enough fuel.
Jim
1982 Saphirblau Baur 325i
Cars all gone!
Or if someone is breaking a 323 the standard pump will do the job, or obviously an e30 325 one will be OK too, as Jim says.
Millar
Post by Millar »
cheers lads, sounds like the cheaper option, which i will probably go for. but just out of interest what about uprgraded ones by the likes of walbro or facet?
murran
Post by murran »
if going for an e30 one, you need a one from a 4 cylinder e30 as these have the return line on the sender (like all e21s). on 6 cyl e30s the return line goes to a pipe on the actual tank. ie; only the feed is on the sender (which isnt like e21s).
Millar
Post by Millar »
oh yeah completely forgot about a fuel return, bugger. will maybe just go for a 323 one then to be safe.
Millar
Post by Millar »
that second fuel line is a must.
I ran a 323i fuel pump and filter from an e21. but it doesnt mount in the usual place as there are no brackets unless you own a 323i - which you dont, so you will have to make some.
fit if the bolts holding your tanks on are a bit rusty, then prepare yourself for a fight with that second fuel line! this job took me nearly a whole day to do.
Millar
Post by Millar »
that is not what i wanted to hear haha, because they will be rusty. actually i think they might have had the fuel tank out when the welding got done, but thats just a bit hopefull...
Have you got any pics of that build? Like where you mounted it and ran the second fuel line?
Jason_323i
Post by Jason_323i »
You car should already have a second fuel line and I have a couple of is pumps in the back of garage so you can fir one in the tank
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Millar
Post by Millar »
sounds good to me. would it just be straight swap then, and connect up the second fuel line? and drop another pump into the tank?
