wich drive axle will fit for my m20 5gearbox conversion
BMW-POWER
Post by BMW-POWER »
hello guys,
im looking for the right drive axle for my m20 5gear conversion, now is a standard 4gearbox mounted, the axle measures 1540 millimeters if its correct, the axle i am looking for should be a little more shorter? because the getrag 242 is a lot longer than a 4gearbox?
can somebody help me to get the length of the right axle i am looking for?
friendly greetings G
E10 2002tii 73'
E21 320/6 78' Anthrazitgrau
E30 325i 86' Diamantschwarz
E30 325iC 89' Diamantschwarz
E36 320iC 94' Dunkelblau
E87 118d 05' Havanna
Re: wich drive axle will fit for my m20 5gearbox conversion
I know there was a topic started about this:
http://www.bmwe21.net/forum/viewtopic.php?f=26&t=9965
Maybe this can help.
paco merme
Post by paco merme »
I have mine did the same thing will happen in exchange for 4 to 5 and what ice is cut in half and weld again, then send it to the lathe for you to stay balanced and everything perfect.
murran
Post by murran »
the extention housing of the 5th gear makes the gearbox 89mm longer than a 4 speeder...... so whatever length the propshaft is now it needs 89mm taking out of it.
