e30 springs fit e21?
cal rat
Post by cal rat »
as above?
cheers
cal rat
Re: e30 springs fit e21?
Post by cal rat »
also do you think these will fit a e21? http://cgi.ebay.co.uk/HONDA-CIVIC-88-00 ... 27b4dcb946
Reck
Post by Reck »
Why not buy springs made for an e21?
If you want to make your own coilovers just use Rally Design components or buy the finished article from Gaz at www.raceperformancemodified.com
cal rat
Post by cal rat »
had a look and the springs rally design supply are the same but different rates! works out cheaper for the ebay jobs also.
reck because 60mm is for knob gobblers gays and confused people. i want 80-90mm :)
rob0r
Post by rob0r »
80-90mm, DIY coilovers or GAZ. If you do DIY coilovers it would be best to shorten the struts and use shorter inserts (E30 2" shorter, saxo 3-4" shorter)
tommi_e21
Post by tommi_e21 »
I can lower my e21 so the sills sit on the floor and im using the rally design coilover conversion kit, costs about £200 and gives you decent hieght adjustable suspension. then its just a case of buying decent dampers but if your not too fussy bumping around the place then just stick with the stock ones
Audi 50 RS
