Suspension rebuild
Reck
Suspension rebuild
Post by Reck »
Looking to rebuild my suspension (and incorporate a 40mm drop). I'm getting a few horrid clunking noises over bumps. I want to do this properly and all in one go.. Can anyone give me a list of bits? Mainly looking for a list of all bushes that will ensure longevity.
Also, can I buy any 40mm drop springs off ebay and put in with oem shocks? Is there anything between the different brands?
Many thanks :)
Re: Suspension rebuild
superflex do a complete set.
i run them and they are pretty cool, you need to measure your front and rear anti rollbar thickness before you order.
heres a link...
http://www.superflex.co.uk/products.php?cat=91
oh yeah, forgot - dont buy the offset camber rear trailing arm bushes - they are always guaranteed to slip at one point and will annoy the hell out of you.
Your best off calling them and requesting a complete set
Reck
Post by Reck »
Thanks man.
Is there anything else that would be good to replace at the same time?
Call Superflex and ask if they'll do a bit of e21 forum discount? You might get a pleasant surprise! ;)
Reck
Post by Reck »
Nice, I'm gonna ring in a few minutes.
Should I ge the rear trailing arm bushes from the dealer then? Also, do I need any special tools to press out the old bushes?
