323i rear brakes conversion
petroscf
My E21(s): '77 EU 316 manual
Post by petroscf »
Ok, this one has been opened before, I am sure of that...
1) The technical question: What is needed for the conversion? What parts must I get?
2) The less technical, and more "a matter of driving feeling" question: What is your opinion, is it worth to do this conversion when the car's engine is not as powerful as the 323i? I mean: let's say that stronger brakes are not what I urgently need. Are there other differences in driving by making these changes on my rear suspension?
/oo=00=oo\
E21 Forever
Re: 323i rear brakes conversion
Bought it recently for my car, what you need is the folowing stuff:
* rear subframe
* lower control arms
* rear struts
* rear calipers
* handbrake cables
* some nuts and bolts
* new rubbers
Jason_323i
Post by Jason_323i »
Sub frame is the same
you need new braek lines as the disk braek are different, also the 323i propotioning valve.
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
petroscf
Post by petroscf »
Thanks!
And...about question no.2?
Are there differences in driving, handling etc. (except for stronger braking) due to the upgraded suspension?
I am asking that because if I remember correctly, someone in a thread wrote that road contact is much better with this upgrade...
/oo=00=oo\
E21 Forever
kABLiuks
Post by kABLiuks »
Jason_323i wrote:Sub frame is the same
Jason
Proportioning valve? Damn it! I have every thing, except that thing...
Without it would disc brakes get more or less pressure than it suppose to get?
There are aftermarket ones, but they are a bit expensive (100Eur+), so may be from E30,E34 it would do a trick?
E21 315 M10b18 Coupe Orange
E36 325 M52B25 Drift missile
E46 330Ci M54B30 Drift GODZILLA
E39 528 M52B28 Touring Black
http://www.cardomain.com/ride/3810901/1981-bmw-3-series/page-6
