The boot rubber seal has come off from one side, so first I'll be cleaning the are where the seal sits.
Any ideas what glue to use to put seal back down securely?
Thanks in advance
Boot rubber seal HELP!
Re: Boot rubber seal HELP!
I always use Bison Tix for that, use enough of the stuff so no water can get in between en remove excess glue right after fitting.
Thanks Jeroen, any ideas what else I could use that is more accessible? Can't seem to get hold of that...was thinking something from halfords?
tiger seal? any high strength silicone should do it though.
Cool cheersnas80 wrote:tiger seal? any high strength silicone should do it though.
I used the glue from BMW.......comes with a brush as an applicator.........good stuff but bloody expensive.....
